Results 1 to 26 of 26
Thread: 2000 civic si sputters between 3-4 rpm
    07 ninja zx10r justin04dc5's Avatar
    Auburn,AL
    Default 2000 civic si sputters between 3-4 rpm
    i have a 2000 civic si and every gear when i get to 3200 rpms or so it will sputter a few times till it passes through 4000 rpms then it does it again the next gear any suggestions
    Macon
    how many miles are on the car?
    Land Rover LR3 HSE
    Auburn,AL
    Jan 2005
    Columbus, Ga
    had a problem like that with my si, I had a clogged cat, caused back pressure and I jumped timing.
    so I suggest check ur cat. convertor abd your timing belt to see if its off
    i know you love my swagger
    OG Black Delegation member
    RIP My Homie Elliot Sloan
    Auburn,AL
    dont have a cat and just changed my timing belt 3000 miles ago. I even took it to a shop they told me it was my oil pressure because of v-tec but i cheaked my oil and it wasn't that. im stumped!!
    cel on? sounds like a bad map sensor
    Auburn,AL
    yea my cel has been on since i put my header on
    i would pull your codes and go from there, sounds a little rich
    Auburn,AL
    yea it smelt a little rich and it smoked just a little when i hit v-tec hard so ill cheak that tomorrow thanks for the help
    Macon
    it is probably either the map sensor or an o2 sensor. Also check your fuel filter. If it is running rich you will want to get a new set of spark plugs as well.
    Land Rover LR3 HSE
    Auburn,AL
    thanks yea ill see tomorrow what codes come up hopefully it wont be anything big
    always check your codes if you have a cel...it'll save you a lot of time by pointing you in the right direction instead of getting an erroneous e-diagnosis.
    find out what your codes are and report back.
    pull codes and i suggest doing ur fuel filter if u have never replaced it
    o2 sensor most likely.
    do a tune up too like plugs, wires, rotor button, your due for it anyway
    Kennesaw, GA
    make sure before you do all that stuff, that your spark plug wires are all tightly connected.
    NIKON Squad member 01
    OF*C
    OEMFitment Crew Memeber 01
    OEM Honda wires!
    NGK
    RISKY RISKYB's Avatar
    athens
    bg fi service wouldnt hurt either....
    Auburn,AL
    fixed it. It was the fuel filter
    Macon
    thats what i thought
    Land Rover LR3 HSE
    Auburn,AL
    it started back again any suggestions
    Boost Junky Jordanmd88's Avatar
    It's your ignition coil.. or your rpm cam sensor in the distributor try swaping a dizzy from a running car.. and i bet it goes away..
    2.2 CL
    Quote Originally Posted by Jordanmd88
    same thing happened to my DA... put a new dizzy and off she went
    dizzy
    Jonesboro/Stockbridge
    Quote Originally Posted by allmotoronly
    that spark plug thing really makes a difference. haha my cousins spark plugs needed to be change and it made us ride horrible cause it was misfiring...so it sputtered
    Quote Originally Posted by JDM onlyy
    What is beign described is Def.. the Internal cam sensor in the dizzy it's skipping a beat... I bet $$ that his RPM Gauge is bouncing around all over the place when it starts to sputter....
