Results 1 to 17 of 17
Thread: WTB: DA halfshaft
    blank
    nowhere
    Cool WTB: DA halfshaft
    need a half shaft from a DA with a manual tranny asap.
    Duluth, G-nett
    same shit for any b series. i have one for sale.
    blank
    nowhere
    they are different. from my understanding. but i am not sure. my axles are binding what do you think it is?
    Duluth, G-nett
    Quote Originally Posted by Bucky
    Half shaft from B18A1 block ( DA ) and halfshaft from B18B1 (DC) are the same. you have axle problems or wrong axles.
    blank
    nowhere
    using da axels so i was told i need a da half shaft. i tried using the half shaft that was on the motor and it didnt work then i tried a da half shaft but i think it was an automatic one. both bind. they bind when your sitting still and just turn the steering wheel. dont have to be driving.
    Duluth, G-nett
    It may be that the axle joints are not connected in the rubber boot. it is easy to pull them out and sometimes can be a PITA to get them back in without taking the boot out.
    blank
    nowhere
    this is the sir half shaft. the da one i have is offset instead of flat like the first pic. is the manual da halfshaft flat or offset?
    if the car is off the ground you can turn the wheels fine but if you put it on the ground and just turn the steering wheel it will bind. dont have to be rolling.
    the da shaft should be shorter than this. i think the one i have is 15" or 15 1/4"
    blank
    nowhere
    anyone
    pm sent
    Banned 1136's Avatar
    kampuchea
    B18a and B18b is different. DA is female and male... DC are both male..
    i got one from a DA. 30 bucks.
    blank
    nowhere
    ^ how does it compare to the one i showed above
    kampuchea
    i have no idea. but i got it off a DA teg. u can come look at it if u want.
    blank
    nowhere
    can you just look for me? i already drove over 2 hrs for 2 others
    blank
    nowhere
    it depends on what trans you have too, because the axle seals are different.
    blank
    nowhere
    bump still need a da half shaft
    blank
    nowhere
    ttt
