Results 1 to 17 of 17
Thread: Lowering Car
    Certified Gearhead Mchnhead2k5's Avatar
    N.Druid Hills
    Default Lowering Car
    I'm thinking about lowering my car but when would I need an alignment to correct the camber settings? Right after the installation or wait a week or so to let the springs settle?
    Thanks.
    1999 Corolla CE & 1988 Pontiac Fiero
    Quote Originally Posted by Mchnhead2k5
    Thanks.
    I'd do it sometime that week, it will continue to settle some but the majority of the differances is the initial install and first couple week or so...
    Jonesboro/Stockbridge
    Yeah, I'd do it sometime that week. Just give it a few days then go get the alignment and you should be good. If it does settle more then it wouldn't be much maybe 1/32's or 2/32's off? Not quite sure but just get the alignment that week. Lol
    N.Druid Hills
    Thanks!!
    SuperLIGHT SUNfire.. madking411's Avatar
    Norcross
    I'm glad you made this thread, Mchnhead, b/c im preparing to get my car lowered as well....i didnt even think about having to get things re-adjusted under there, or havin a ''break-in'' period....
    2.2 CL
    i didnt know either till i slammed mine and now it shoots to the left side of the road everytime i let the steering wheel go haha
    Fayetteville/PTC/Carrollton
    Quote Originally Posted by SLo_MKIII
    haha my car does exactly the same thing, pulls to the left like a motherfucker whenever you let the wheel go. but, i ordered a camber kit that should be in this week that is gonna fix that without me having to go get an alignment cause i dont trust other people aligning my wheels too haha.
    Norcross
    Quote Originally Posted by ryanh300
    wait, why not?
    N.Druid Hills
    camber won't make you pull left/right, it's the Toe In/Out that will make you pull. Negative camber will just wear out the inside part of the tire quickly.
    How to you propose on aligning it yourself?
    AWD OH MY KPowerEP3's Avatar
    Ellenwood
    toe will eat tires up even worse, though.
    IA's metal head
    Duluth
    that's what I was wondering myself.
    ...ninja
    N.Druid Hills
    Aligning yourself: 4 jackstands, a Haynes/Chilton manual, a long piece of STRAIGHT wood or pipe and a person who knows what they're doing.
    pipe is too flexible and wood isn't ever gonna be straight enough.
    Try a string Got a setup at the shop for alignments at the track, 1/2" EMT the width of the car plus an extra 6" or so on each side that mounts to the screw holes for the license plate...tie the string to the front and rear as close to the wheels as possible and using a metal ruler measure the distance from the string to the front and rear of each wheel. Can get within 1/64" on the toe.
    N.Druid Hills
    my friend uses a metal pipe he has kept for this reason of aligning.
    INFINITE TRDwasiq's Avatar
    lowerin ur corolla?? need any help let me knw
    Hwy 315
    i use a mic with my string
    DIY alignments FTMFW
    -jonathan
    [/URL]
    Jesus Christ is my Savior
