Results 1 to 21 of 21
Thread: 99 civic EX Auto to Manual Swap HELP!!!
    Southside Ridin HATCH
    Default 99 civic EX Auto to Manual Swap HELP!!!
    I just did the swap everything is fine except the "IAVC" my car wont idle rite... What do i have to do with the wireing?????
    everything should be fine, with iacv, i have never had a problem out of them when i have done auto-manual in civic's. Does it throw a light what?
    um.. ? what kinda re wire did you have to do when u did the swap?
    I usually only have to rewire things on the inside of the car auto lock out swith etc. Did you use a 5spd ecu?
    no , thats what i think the prob. is im gettin one in a couple days when i find one.
    there u go dude. make sure your year model doesnt have an immobilizer, or you will have to get it reflashed to match.
    allrite , what about the map sensor? i got a SKUNK2 mani. and throttle body. idles funky. any answers?
    skunk 2 throttle bodys stick... adjust the cable. check tps , check vacuum lines, check iacv, you have no more fitv so it could be that. etc
    allrite thanks yo.. ill post up again if i have more probs. with it.
    Low-n-Slow iEvo's Avatar
    Gnett
    yea "EmminoDaGreat" knows his shit. ull deff need the 5speed ECU for it to work right
    warner robins
    i just did a auto to manual swap on a 00 civic a couple of weeks ago. i used the auto ecu and it runs fine
    JJSPEC.COM
    what wireing did u do? if u can help.
    if you have an ek auto ex or dx 5 speed or manual it uses a 3 wire iacv that needs to be rewired if you are changing to 5 speed ek or any other besides the dx ek chasis and vice versa. if you don't convert to the appropriate iacv wiring/plug it'll idle like crap.
    i can get you the info on the repinning. answer this first:
    your chassis is a 99 ex auto right? what are you swapping to engine and ecu?
    That would deff be the problem!
    Quote Originally Posted by Black4DrEK
    Yea its a 99 auto ex D16Y8, i changed to 5speed and put the Skunk2 intake mani. and Skunk2 throttle body.
    did you get a 2 wire iacv? there should be a couple holes on the back of the intake manifold where it goes. you'll need to repin the harness at the ecu.
    move b6 to empty b23 and remove b15
    thanks alot . is that it?
    you'll also need to come up with a 2 wire plug for the iacv. honda uses the same plug on a few other sensors throughout the car so go to pull a part and cut one off...leave yourself plenty of wire to solder it in.
    my plugs are 3 wire plugs.? for the iacv. those wont work?
    no...5 speed ex uses a 2 wire iacv that you'll have to add if you don't have it and you'll have to do the repin/rewire. i forgot to tell you how to wire in the 2 wire plug didn't i.
    you may not get the same wire color on the 2 wire plug unless you specifically cut it from the iacv on a donor car, but you can see the orientation of the wires in relation to the release on the plug.
    Attached Thumbnails Attached Thumbnails -3-2wireiacvfix-jpg
    thanks.
