Results 1 to 17 of 17
Thread: New Exedy Clutch and Lightweight Flywheel
    Norfolk, VA
    Exclamation New Exedy Clutch and Lightweight Flywheel
    EXEDY Clutch & FIDANZA Flywheel 89-91 HONDA CIVIC / CRX
    Fidanza Aluminum Flywheels are made using the highest quality, most modern materials available. The flywheel itself is made from 6061 T6 billet aluminum. It is CNC machined at a constant surface speed for durability and finish. The friction surface is very special. Fidanza uses a 1050 high carbon, alloy steel. It is incredibly durable, allowing the user to use just about any clutch disc material available. The friction plate can be machined or replaced as needed. The plates are secured with 16-20 hardened aircraft quality screws with self locking nuts which prevent any warping. Fidanza uses hardened ring gears that are swarted to the flywheel with button head screws that are counter board between the flywheel and ring gear to prevent any possible slippage. The mass at the center of the flywheel is retained for strength, but the mass at the outside is eliminated for optimum performance.
    • Ultra Light and weighs only 7 lbs
    • SFI approved 2 part design with replaceable clutch contact plate delievers the highest quality and logest service life of any flywheel available.
    • Fidanza flywheels work with every clutch including Exedy, ACT, Fidanza, Clutchmasters, and other OEM clutch kits
    • Fidanza Part number: 191161
    • Made in the U.S.A.
    Will fit:
    D15, D16
    Just Flywheel: $125.00
    <---Click it.
    Norfolk, VA
    oh, I bought it off ebay and it didn't fit my car :\
    <---Click it.
    Snellville/Statesboro
    i was about to ask why u wanna sell, but then u said it didn't fit your car.
    sucks
    g/l
    UPROOT Photography FTW
    Norfolk, VA
    for some reason my front end is off by 3 years, lol
    <---Click it.
    Norfolk, VA
    ttt
    <---Click it.
    Norfolk, VA
    OBO
    <---Click it.
    Duluth, G-nett
    $115 + $125 = $240. not $250. bump for joo
    Norfolk, VA
    opps, thanks for pointing that out
    <---Click it.
    Norfolk, VA
    i really need these to sell
    <---Click it.
    Norfolk, VA
    ttt
    <---Click it.
    Norfolk, VA
    ttt
    <---Click it.
    Norfolk, VA
    ttt
    <---Click it.
    1979 Civic Cvcc Saung's Avatar
    Tucker
    hey. is the flywheel good for daily driving or just for the track only? thanks
    Norfolk, VA
    daily driving or track. it only weights 7lbs!!!
    <---Click it.
    Norfolk, VA
    clutch gone.
    <---Click it.
    AKAudioINC AKAudioINC's Avatar
    Carrollton/Kennesaw/Douglasville/Peachtree City
    I just thought about ordering that same flywheel, what made it not fit on your block? I'm putting it on a D15B SOHC VTEC w/ a 89 5spd tranny...
    Augusta Ga
    Quote Originally Posted by Whiteboy™
    buahahaha !!!
    93 sol Si
    95 sol S
    95 sol Si
