Results 1 to 18 of 18
Thread: WTB: 10 or 12 inch sub, sub box, amp...
    Snellville/Statesboro
    Default WTB: 10 or 12 inch sub, sub box, amp...
    I want a little bass in my ride. I've got a 4 channel amp for my door speakers and it sounds great, but i want sum bass that my door speakers dont put out.
    I had 2 audiobahn(sp) subs in my hatch before, and the bass was just too much for me. A 10 or 12 inch sub will be fine for me.
    LMK what ya got
    UPROOT Photography FTW
    __DailyGrind
    i got one 12 i think or 10 ...lol its belong to my buddy , and also an Xtant AMP . 250 for both amp and sub. *sub is in a box already*
    BadAssNinjaTrunkMonkey
    I have an audiobahn 12 DVC sub and a kenwood 800w amp pushin around 760 tru power and I can build you a box for it for $250 total or I have a box for two 12's ported and tuned for a hatchback but the price would be another $50 lmk
    geez, lol this seems to be a little more expensive than i thought...
    anything in like the $150 range?
    I can go $200 on the sub, amp and building a box. lmk
    boost wanted GermanMuscle's Avatar
    Duluth, GA
    ***Kicker 12" CVR***
    12" kicker CVR $40
    i have one in my integra and it sounds great.
    90 Integra....Sold
    96 Jetta VR6...current money pit
    i'd rather buy everything as a package deal, you know like everything at one time.
    your sub is a deal germanmuscle, though. i'll definatly keep that in mine
    ttt
    mine is everything at one time? not following? lmk
    Quote Originally Posted by Grnblur
    you want $200, and i dont want to spend more than $150 if that.
    I also dont want to lowball you because ik it's worth every bit of what you're asking for it
    Senior Member JASONBALL's Avatar
    columbus GA
    I can sell ya 1 metrik sub amp and 1 10in metrik sub.
    stand by for specs
    columbus GA
    I can do these for $150
    MAB-901 $160 retail
    1900 WATT MONOBLOCK HIGH POWER MOSFET AMPLIFIER
    1900 WATT DYNAMIC POWER @ 14.4 VOLTS
    950 WATTS X 1 @ 2 OHM
    600 WATTS X 1 @ 4 OHM
    S/N RATIO >90 DB
    REMOTE BASS BOOST CONTROL
    QSINK TECHNOLOGY (HEAT MANAGEMENT SYSTEM)
    MULTI FUNCTION VFD PANEL DISPLAYS: VOLTAGE/TEMPERATURE/AUDIO LEVEL
    BOARD MOUNTED TEMPERATURE SENSOR • HIGH FLOW COOLING FAN
    CONTINUOUSLY VARIABLE PHASE ADJUSTMENT
    LINE OUTPUT FOR MULTIPLE AMPLIFIER SYSTEMS
    VARIABLE INPUT LEVEL 5V TO 0.2V
    BUILT IN ELECTRONIC CROSSOVERS
    12DB VARIABLE BASS BOOST @ 45 HZ
    ON BOARD SUB SONIC FILTER 15HZ – 55HZ
    ON BOARD LOW PASS FILTER 40HZ – 150HZ
    ELECTRONIC OVERLOAD PROTECTION
    19"L x 10.25"W x 2"D
    12 lbs.
    10” PEARL WHITE SUBWOOFER
    400rms 900 peak
    ONE-PIECE SEAMLESS POLY PROPYLENE CONE
    OVERSIZED RUBBER SURROUND
    SILVER DIE CAST BASKET,
    HEAVY DUTY CHROME PUSH TERMINALS
    BUMPED & VENTED CHROME T-YOLK
    2” DUAL KAPTON VOICE COIL
    50 OZ STRONTIUM MAGNET
    4 OHMS
    FREQ. RES: 31 HZ – 1.5 KHZ
    SENSITIVITY: 90 DB/W (1M)
    PM'd
    columbus GA
    hit ya back
    atlanta,ga
    Default 10'' Rockford Fosgate P3 shallow mount
    I used it for a week, but need a good box. The box I had wasn't sealed good. I took it out and don't want it anymore. I'll let the sub go for $150.
    Its a dual 4 ohm voice coil sub that can take 400watts rms.
    Crutchfield has these for $180 on sale right now.
    Mike 404 583 5811
    boricua chrisdohck's Avatar
    got a sony 10" xplod with box and amp for 150 sounds good lmk
    you interested in a 12" solobaric L7?
    Jonesboro/Stockbridge
    check out my thread....
    FS: 2 10" Rockford Fosgate Punch & box
    and make me an offer
