Thread: bolt broke off in intercooler
    02 WRX patrick4588's Avatar
    warner robins
    Default bolt broke off in intercooler
    when i was mounting my intercooler, one of the bolts broke off inside the threads. how do i get it out?
    Broke sullen's Avatar
    Acworth
    old tool and die trick
    get a center punch small enough to get in the hole. get a hammer. orient the punch at an angle, aligned to force the bolt to move counter clockwise. hit the punch repeatedly. that should work.
    or... go buy a easyout. i have some if you are nearby...
    warner robins
    im in warner robins, so im not nearby. how much is an easy out? ill try the first thing before i buy one. thanks.
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    easyout doesnt work... dude the easiest way is to just grind the sides flat and use a wrench/socket to turn it out with some pb blaster
    dunno easyout never worked for me
    (oo=[][]=oo) slowrolla97's Avatar
    Marietta GA
    I have gotten mani bolts out and valve cover bolts and many other kind of bolts out with an easy out. You just have to have enough room to make a straight hole with a drill.
    240atlanta.com
    Acworth
    how do you grind the sides of a broken bolt down in the threads? please tell me...im waiting to hear back on this one. easy outs are kinda expensive actually. like $12. but yea, just have to be able to drill a completely | vertical hole in the bolt. doesnt have to be deep, just enough for the easy out to get some grip on the tip of the thing. if that wont work try my first trick. used that many times on lots of broken shit. always works...
    HIV+ HalfBaked's Avatar
    Just drill it out.
    JDM TYTE AnthonyF's Avatar
    Quote Originally Posted by sullen
    x2 they are a few bucks
    The Carbon Fibered R6
