Results 1 to 32 of 32
Thread: D16Y8 Swap?
    Default D16Y8 Swap?
    Ok, im swaping a complete swap into my 93 hatch.... What would I need to make this work in it. Now remember I have the complete swap. Also run right?
    Swap: D16Y8 complete swap
    140 on one wheel
    columbus, ga
    sell it to me
    140 on one wheel
    columbus, ga
    you need a wiring harness, mounts, injectors, ecu, alternator, starter and maybe a few other small items.
    Southside
    You'll also have to change out your T-bone bracket. Hmmmm if that is an obd 2 motor, then if your not going to splice the harness for your dizzy, starter and alternator on the swap, you'll have to get all obd 1 instead for it to plug and play.
    T-bone bracket? explain....
    Quote Originally Posted by JDM_EK4
    Southside
    that's the bracket thats connected to the firewall the hold your tranny
    Southside
    inline four has the bracket for our swaps way cheaper than what a honda dealership would sell them to you for. Cause I'm bout to put in a obd 2 motor in my EJ as well and I think it's the DAs T-Bone bracket now that I think about it.
    Ah ok Thanks. Could I just get it off the car that im pulling the engine form 99 civic EX?
    Southside
    Damn...lmao I don't know why I'm thinking your putting a B-Series in your car...hhhhmmmm I'm not to sure on that, I have a friend I could ask.
    B-series should just go inn without no problem you dont need that bar or whatever.
    Friend droped a Type-R into his hatch without no problem man. IDK what kinda B-swap you putting in
    Southside
    B16A2
    Man it will drop inn with no problem and bolt rigth inn. Who told you that u needed to change that bar?
    B16A2
    JDM TYTE AnthonyF's Avatar
    kool little swap. will it be all motor? I would reccomend building it while it's out of the car. It makes it so much easier. If ur not, o'well.
    from what I know, it should drop right in. I would suggest getting new motor mounts, pref. urathane to get all the power down. The only ones that need diff mounts are the B-series.
    The Carbon Fibered R6
    Southside
    Yea the motor is built just waiting to get my head back, it's an 00 J-Spec, and I have the mounts and all, I wont be dropping it in until I move in the next 18 days to my apartment cause the garage is hugh and I'll have enough space to do what I need to.
    Southside
    I'm dropping an OBD2 motor in an OBD1 car my EJ
    Well form my stock D15b7 with 70hp to D16y8 with 130hp ill be able to tell the diff. Ill going to turbo it later on the year, but im gong to build an extra y8 block that I have for later use.
    Question, why not build up the b7 with vitaras and rods for a nice turbo set-up? Just wondering.
    may i ask what a b7 is??
    San antonio 210
    go with a b18c1
    I would, but the y8 is free and complete.
    go with a b18c1
    San antonio 210
    Quote Originally Posted by GSRteg
    DO IT... free shit is the best shit
    Damn right! Came home one day and there it was a whole car including the y8
    San antonio 210
    lucky ass lol
    WEST_SIDE
    it will drop right in man . just use your ol dhareness and obd1 dizy. basically use everythign form your old motor all you really need is a lil wiring
    Titties!!!
    i have put a d16y8 in a 95 civic dx. i used the factory harness, the brackets from the b7 motor, you can rewire the dizzy for the ckp sensor. basically if you keep the car obd1 then you would need to use the sensors from an obd1 car. when i did my swap all i had to run were the vtec wires to the ecu. i used the d15 manifold, injectors, tps. on a y8 the crank anglke sensor is on the crank pulley, previous years it was on the dizzy. i gutted a z6 dizzy and put all the interals in a y7 dizzy so it will bolt to the head. the z6 dizzy will bolt up with some mods, but fuck leaking oil. that and the bitch always came out of time til i switched the dizzy. you can pm me more details since i just did this 5 mos ago.
    Damn thats sounds like alot of work. I also want to run the air and ps.
    Southside
    Yo GSRteg, if you ever want or need help with the swap just pm me with a day.
    college park
    what tony actually told somebody about his super secret swap get tha fuck outta here im scratching my head on this one
    now with LSD
    Remember the y8 was free!
    go with a b18c1
    Because the y8 was free!
    Quote Originally Posted by redciv1
    Southside
    I didn't give out too much info....
