Results 1 to 4 of 4
Thread: protection light on amp?
    georgia
    Default protection light on amp?
    what are some reasons a power portection light will come on a amp? my subs are kickers and they have dual voice coils and are 2ohm's each.
    i have the amp bridged and if i try to run both subs the amp wont allow it,but it worked pretty good with only one hooked up until today.the protection light came on and i have checked all my wiring and i cant get it to go off.
    yes i am....
    Certified Gearhead TrickcitykustomsPrez's Avatar
    Blue Ridge, GA...AKA BFE
    sometimes when you do your ground it doesnt get a good connection. try taking a grinder to where you are grounding it to get any paint/debris off. if that doesnt work it could be an over load on the amp to push them both or try not bridging them.
    It is said that something as simple as
    the flutter of a Butterfly's Wing can
    ultimately cause a typhoon halfway
    around the world.
    -Chaos Theory
    Hiram, GA
    reasons for prtotection:
    low voltage, could be bad ground, too small guage of wire, or a bad connection
    load protection, could be too low of resistance from a bad coil
    overheating, probably not this if its lasted for a while already.
    jimmy covered it
