Results 1 to 15 of 15
Thread: Testing Waters: 1995 240sx w/ Built Ka-t
    Default Testing Waters: 1995 240sx w/ Built Ka-t
    Hey guys, just got my s14 earlier this week. It's been a long, hard process that's lasted over a year with the shop that I delt with. Basically the car was paid for and the shop decided to take a lot longer than they should have... With this being said.. I'm not really sure I want the car anymore so I'm just checking interest and seein if anyone wants to make any tempting offers.
    The bad: The car has about 20 miles on the rebuilt engine. Picked up the car and got about 10 mins down the road and had an oil leak. The car is at a Nissan dealership right now getting fixed. Once the leak is fixed the car will be checked over for any other possible problems. Still needs 500 miles break-in. A few small dings. Interior is worn. No radio.
    The small issues (carpet, shift boot, cracked lenses) will hopefully be resolved soon as these are cheap fixes for me.
    1995 240SX
    130,xxx miles on chassis
    About 20 on rebuilt engine
    New Red paint job
    $14k OBO (again, just gauging interest)
    Built by E&E Motorsports (Dallas, GA)
    Stage 2 engine build including:
    Block
    Engine is fully disassembled
    Engine is Hot-tanked, decked, and checked for cracks
    Block is torque-plated, and bored to 90mm
    Crank is polished, and checked to make sure it is within factory specs
    Freeze Plugs are replaced
    Full rotating assembly is balanced
    Block is reassembled with
    E&E Motorsports custom JE Pistons
    Crower Rods
    Calico Coatings, coated ACL Race Series bearings
    ARP Head Studs
    Oil pump is checked and made sure to be within factory specs, if not it is replaced
    Oil relief spring pressure is raised to increase oil pressure
    Full timing assembley is replaced with upgraded OEM units, upper and lower chains, upper and lower tensioners, upper and lower guides, and cam sprockets
    Water pump is replace, and NISMO thermostat is installed
    Oil pan is reinstalled with Oil return bung installed for turbo kit
    Head
    Head is disassembled, cleaned, and checked for cracks, and reassembled
    3 Angle valve job is completed
    Shims are set to factory specs
    Head is ported and polished
    Combustion Chambers are bowl blended
    Exhaust ports are gasket matched
    Cometic head gasket
    Turbo Setup
    E&E Motorsports Log Style Turbo Manifold
    Turbonetics Turbo - T62-1
    Turbonetics Evolution Wastegate with 10lb spring
    Apexi SAFC II
    24x12x3 inch bar & plate FMIC
    2.5 inch Intercooler Piping
    HKS SSQV BOV
    Downpipe and full 3 inch turbo-back exhaust
    Z32 MAF
    Top-Feed Fuel rail
    550cc injectors
    Stainless Steel braided lines
    Aeromotive Adjustable FPR
    WALBRO 255
    Oil lines
    Others
    Stage 5 clutch
    A/F & Boost gauges in dual pillar
    Eibach Sportlines
    Koni Yellows
    Drfit bushings
    Stock front wheels.. Rears are 300zx wheels
    I'm sure I'm forgetting a few things, but I'll add them if so.
    Let me know if there's any interest!
    Justin
    cant link pictures...
    what is that supposed to mean?
    sick setup btw...any dyno numbers?
    oh and PRICE??
    not sure.. just basically copied from E&E's site.. no dyno numbers.. like i said i pretty much drove the first 10 miles when i picked it up. "should" put down around 350whp at about 12psi according to the shop. as far as price i'm not sure... really trying to gauge interest... guess i'll just list it high and consider offers...
    Jan 2005
    Columbus, Ga
    Please post pictures and a price, even if your testing waters, need an ideal price ur lookin for and u can obo it
    i know you love my swagger
    OG Black Delegation member
    RIP My Homie Elliot Sloan
    would be great
    Pics added!! Anything else let me know
    Athens/ATL
    Just some advice for the seller... if you're really serious about getting 14k for this car, I would invest the $500 or so to fix a majority of the little things wrong with it and make it really clean... IE the shift boot, fog light, etc. Do this asap lol. Clean car though all in all. And don't get offended if people offer you $8k and below for it.. just a heads up.
    damn , what happened to that shift boot!!
    Norcross
    Quote Originally Posted by BenefitX
    LOL Thats What I Was Thinking.
    Athens/ATL
    ^^ looks like hunger in atlanta traffic lol.
    I doubt you will get it to run right or 350whp out of it with a S-AFC.. but GL on the sell to a fellow S14 owner
    ya... shift boot? not sure!! mountain lion maybe? anyway... those things should be fixed fairly soon. and don't worry i won't be offended for offers under 10k... i'm expecting it
    and ya the SAFC was a last minute thing.... so we'll see what happens.. first priority is the oil leak! lol
    Henry Co.
    do you run a filter on that inlet? id hate to see a rock take out that shiny thing.
    bump for a fellow Kitty KA-T
    ya i'm plannin on puttin a filter on it
    where is your MAF sensor placed?
