Results 1 to 19 of 19
Thread: WHY CAR IDLES AT 3K ???HELP
    southside
    Default WHY CAR IDLES AT 3K ???HELP
    my car seems to idle very loud it idles at 3k we adjusted the cord or cable and it stil idles high
    Duluth, G-nett
    check for vac leak.
    h series
    norcross
    does it fluctuate or is it constantly at 3k
    Senior Member BlkCD5's Avatar
    check your cables again and do what they previously mentioned. Btw Vien, your car is teh sex.
    h series
    norcross
    Quote Originally Posted by BlkCD5
    my car is now sold to my uncle man. i gave it to him for low ass hell though. thinking about getting an integra or civic now.
    IACV?
    vacuum leak
    Im with Mr. Kidd on this one
    vacuum leak
    southside
    ok which line would it be and yes it is constant 3k doesnt go up and down like when i shift it does drop down below 3k
    southside
    so wat parts do i need to purchase
    ®anj-♠ ranj's Avatar
    test it for a vacuum leak first, then go from there
    southside
    how do you test for vac leaks i checked and i am missing a vacuum line that goes to the valve cover and i have to vac lines goin to a small cimpondezil
    Duluth, G-nett
    if there is no vac leak, readjust the throttle position. it has a small jam nut on it, loosen it and turn it down a bit.
    Quote Originally Posted by corey30349
    you search for hissing sounds, then gently wiggle every single vacuum hose checking for changes in noises.
    When did this start and was there any work done on the car prior to it doing this?
    everywhere & nowhere
    1st thing is to check the coolant level. If it's a B series and the coolant level is low it will idle high. DO not assume it's a vacuum eleak right away. If you have coolant, then make sure that the cap is good - any amount of extra air in the system will confuse the sensors and ECU.
    southside
    I checked out all the hoses and non have leaks or anything but on the inside of the tb the rubber pieces that are suppose to be in the two holes are missing could that be causin high idle
    I don't knwo if this will help, but try this one
    Idle problem write up
    haha yes, the idle write up has once again saved another engine from poor idling qualities!
