Results 1 to 4 of 4
Thread: what PSI is the FUEL CUT on 1g Eclipse?
    Oct 2003
    Exclamation what PSI is the FUEL CUT on 1g Eclipse?
    I was told 8psi
    is it true? I would post in Mitsubishi section but ppl barely check there
    and which solenoid/map sensor on the car (location) reads boost level?
    Oct 2003
    hmm been reading up on some shit and found out it could be due to excessive airflow reading from MAF....how can i fix this?
    I got a pt67 on this damn car and hit fuel cut at ~3200rpm @8psi right when the turbo spools up....oh did i mention a 58ar on the hot side so it spools up quick as fuck on this t4
    Oct 2003
    i got a hks FCD and a MF-2 that i am going to put on but i dont know is the fuel cut is due to boost level or excessive airflow
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    sounds like you need to throw some d's on that bitch
