Results 1 to 11 of 11
Thread: what size trottle body should i go for?
    khmer empire foo!!
    kampuchea
    Default what size trottle body should i go for?
    I have a jg intake manifold, wondering which size should i go for? 70mm or bigger?
    man get dat 100mm tb!!! LMFAO and a fuckin exhaust with that loud ass shit
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    why are you even going with a 70mm??? what type of mods do u have or planning to go with?
    he got built all motor b18 w/b16 head ctr pistons, stage 2 cams and so on...............
    ECEFC.com
    Is he running it on pump gas? if so, with a build up like that (LS/vtec with ctr) is a driving time bomb due to high compression.
    68mm TB, and the JG is too big for that setup. youll see more power with the AEBS/SKUNK2
    my bad its a gsr block.... and yes pump gas
    WEST_SIDE
    do what i did get a 4 inch xhaust pipe cut it to lenght modify for a BF and throtltle cable and bang , instant HP
    for got to meniton installed it on your IM
    s1000
    clayton county/cobb county
    68 or 70. no bigger.
    one kill wonder remoer's Avatar
    in hell
    wow i'm not the britest bulb in the pack, but i will say if you have an allmotor build a 62mm is way enough. in fact here's my build i'm in the process of:
    HEAD
    Bisimoto - head work and parts
    D16a6 head
    5 angle valve job
    stg 3 cam - hardweld: 0.472/0.449 (268/252)
    Springs + Titanium retainers
    Bisi's adjustable cam gear
    Bisi's header
    RS*R Ex-mag Exhaust 60mm piping
    D16z6 intake manni port match for tb (only to break in the motor)
    B18c 60mm tnrottle body (only to break in the motor)
    AEM cold air intake (only to break in the motor)
    CBR929rr 42mm individual throttle bodies (once engine is broken in)
    D15b2 intake flange cut and pipes welded for itb's till i can afford a CNC flange w/pipes
    Speak English Or Die!
    1 monkey power = 0.332 hp.
