Results 1 to 10 of 10
Thread: p28 trouble light
    georgia
    Default p28 trouble light
    i cant find any thing about it. but the light flashes 1 time then stops and then it flashes again 7 times. whats the deal?
    yes i am....
    Why dont you go buy a manual form Auto zone im sure it explains what it is and how to fix it. Just a thought man holla.
    Isnt that code 17 correct me if im wrong?
    If so its the VSS (Vehicle Speed Sensor)
    defective circuit or unplugged / defective sensor
    h series
    norcross
    are they short flashes or long flashes
    could be code 17, code 1 and 7, or code 10 and 7. depends on how it's flashing.
    long flash=10 and is about 1 second long
    short flash=1 and is about 1/2 second long
    codes are seperated by no light for about 2 seconds
    once all codes are shown they will continue to repeat until the svc connector is unjumped.
    code 17=vss
    code 1=primary o2
    code 7=tps
    code 10=iat
    True that!
    code 17=vss
    code 1=primary o2
    code 7=tps
    code 10=iat
    georgia
    its a quick 1 flash then a pause. so im guessing my o2 still is not hooked up correctly..dammit. and tps i have no idea how to fix that if its a wiring issue.i hate this shit. i will put another throttle body with good tps and see if that helps. if it is a vss code how can i fix that? im not sure if my car actually has one. oh and after it shows all the codes it will not repeat 1 and 7 it will only do the long single flash and then stop.
    yes i am....
    on a socketed/chipped ecu the o2 can be disabled, but it would definately need to be tuned.
    turn off the car, disconnect the ecu for 30 seconds then recheck the codes. i've never seen codes not repeat.
    you can replace the vss. it should be sticking up from the tranny case (i think it's held down w/ 1 10mm bolt) w/a plug to it.
    georgia
    thanks,i thought my trans did not have one because it has a speedo cable? well on my s-10 and firebird they dont use a cable only a sensor.
    yes i am....
