Results 1 to 3 of 3
Thread: need help on wastegate problem civic
    Yum-Yum Racing
    Default need help on wastegate problem civic
    aight i got sohc boost t3/t4 turbo with the tial 38mm wastegate and a 3.63 psi spring but idk what is wrong here.
    Heres what happens:
    If i press on the gas hard from a stop the car goes but the wastegate opens from about 1,000rpm to 2,000rpm then closes boosts up and then reopens on the setting for the boost controller.
    If i get on the gas progressively the wastegate doesnt open until it is supposed to on the boost controller.
    Also the same thing if im am already rolling i have to progressively step on the gas or else the wastegate opens
    Any help would be great
    First off, i like how you post this question, but your sig says "you wont regret it". Apparently, they will. Anyways, try switching out the spring, if it happens again, repost the problem.
    what boost controller do you have and what are the settings?
