Thread: engine question,
    YR88 Win! Romeo's Avatar
    Middle Ga.
    Default engine question,
    is the F22B2 vtec or non-vtec? cause i just bought an accord with the F22B2 and the guy claimed it was vtec but said the valve cover was cracked so he put another one on.
    Roswell, GA / Georgia Tech
    Quick Wikipedia Search......... don't know if it helps or not
    F22B2
    This engine was used in the 1994-1997 Honda Accord DX and LX. The F22B6 in the 1995-1997 Honda Odyssey and the F22B8 in the Honda Shuttle are substantially similar.
    Specifications
    * Bore × Stroke: 85.0 × 95.0 mm
    * Displacement: 2156 cc
    * Valve Configuration: SOHC, 16 valves
    * Compression ratio: 8.8:1
    * Max power: 130 hp (97 kW) @ 5300 rpm
    * Max torque: 139 ft·lbf (188 Nm) @ 4200 rpm
    IA Member Mr.Leftlane's Avatar
    Check around the left side of your valve cover either in front or behind the distributor for the V tec solenoid.
    Negative, it came in accord lx and dx models=non VTEC
    Its non VTEC like the guy above says.
    definitly non
