Results 1 to 16 of 16
Thread: FS: JL Audio 12W6 in custom enclosure
    IA Member Himoto's Avatar
    Default FS: JL Audio 12W6 in custom enclosure
    One JL Audio 12W6 mounted in a sealed box made exactly to JL Audio's specs for optimal sound quality. The enclosure is made out of 3/4" MDF but I have not covered it, so it's just bare wood. I've also added a grill to the front of the speaker to protect it from damage.
    If you've been around car audio much, you know the reputation this model has.
    Subwoofer Specs:
    Dual 6 Ohm Voice Coils
    300 Watts RMS
    500 Watts Peak
    Enclosure Specs:
    3/4" MDF
    1.25 cubic feet volume
    18" x 13" x 13.75"
    Detailed Product Specs
    $160 OBO
    Please PM me if interested.
    Shoot me an offer if you're interested.
    Bump.
    Bump.
    Certified Gearhead lilguy's Avatar
    NE ATL
    bump for jl audio
    Bump.
    Bump.
    Bump.
    Dual 6 ohm voice coils? Im confused. How would you wire that?
    ***Lotus Elise***
    BlackWatchRacing
    You can wire it in series or parallel depending on if you want your amp to see a 3 or 12 Ohm load. Very handy in certain setups. Right now it is wired for 12 Ohms because the crappy amp I'm using to drive it is only stable down to 4 ohms.
    Quote Originally Posted by Himoto
    Weird. I have never seen that before... Normally just dual 2 or dual 4.
    ***Lotus Elise***
    BlackWatchRacing
    if u still got it ill hit u up wen i gots some money
    Still have this. PM me if you're interested.
    Athens area
    That was back in the day when you could buy 3 8,10,12, or 15w6's and wire them up to get a 4 ohm mono load. Usually three subs were the ideal width to fill the length of a trunk. JL Audio also had those triangular custom fiberglass mounting plates you could buy. The 4 ohm mono load is perfect for amps, but it sucks when you try to run 1 or 2 subs. With one sub you could run the 3 ohm mono(1.5 ohms stereo) load, but some amps couldn't take that impedence long. They are GREAT subs though.
    Yes, I really do love the way this sub sounds. I wouldn't be selling it if I wasn't strapped for cash. It really is a great sub and I'm pretty sure if I sell this one I'll have a hard time replacing it. If I end up selling my Integra before I sell this I will probably just keep it, finish the box, and put it into the daily driver(Accord).
