Thread: FUEL AND SPARK...STILL WON'T CRANK
    southside ATL
    Angry FUEL AND SPARK...STILL WON'T CRANK
    i have a 00 civic si. i changed out the rotor button and cap...it was running fine before..but i decided to do it since i was doin a rutine tune-up. well i took of the distributor and put all the new stuff on it...put it back and now it wont start...i hear the fuel pump turn or whatever when i turn the key and i checked for spark..but still wont crank...im pretty sure the spark plug wires are in the right sequnce??
    ps. the distributor was hard putting back in..i checked to if it was alighn with the cam and all
    should i check the timing?
    compression?
    new distributor??
    i really need help
    BABIES "R" US crew
    2.3 Evo 8
    Guest
    Put it back the way it was if you can't get this to work.
    Oct 2003
    you prolly put the spark plug wires on wrong on the cap
    Oct 2003
    bottom left is #1, bottom right is #2, top left is #3 top right is #4
    Oct 2003
    #1 cylinder is the closest to the pulley/belt side
    JJSPEC Racing
    sounds like wires may be in wrong order as stated above, if that isn't it then i would check the timing
    -2001 Lexus IS300
    Yeah what they said spark plug in wrong order....
    Drifter/Kneedragger
    Buford, GA, USA
    are you saying you pulled the whole distributor out to change the cap/rotor?
