Thread: WHEEL FITMENT
    RISKY RISKYB's Avatar
    athens
    Default WHEEL FITMENT
    will a 2000 integra hold a 17x8 without rubbing or scrapping
    Senior Member sprix!'s Avatar
    It depends on the offset...
    G37s 6MT/coupe
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    kinda wide dont you think?
    Yep it depends on the offset like buddy said above me!
    the old man NAIZBST's Avatar
    it will be able to hold without rubbing or scraping if it is a positive offset of I believe a 30 to 45
    IA Retiree Twinnos's Avatar
    Mar 2003
    3 magazine features later......
    how do you determine offsets. lets say i go with 19x8.5 in front with regular front fenders and 19x10 in rear with extended rear flares and i want the rear tires to be flush with the rear fenders. the question: would a +38 offset push the rim out further to be flush with the rear fender flares than +45 offset?
    its kinda wide..but it does dependon teh offset
    70hp FTL StraightSix's Avatar
    Central, SC
    Offset is the measurement from the center line of the wheel to the mounting face of the wheel. Most FWD, and some late-model RWD cars will use high positive offset wheels.
    A +45 wheel should sit farther under the car than a +38, to answer the question above and provide an example.
