Results 1 to 17 of 17
Thread: Freakin stupid turbos
    20 side of thangs
    Angry Freakin stupid turbos
    Any tips on how to seperate the exhaust housing from the center section? i know its supposed to rotate but mine seems rusted on. Any ideas tobreak it loose? i tried hammer, wd-40, deep creep, and nothings happening. i need my freakin car to run!!!
    are you trying to clock it
    torch son, add a little heat
    Gainesville
    hair dryer? and a flat head screw driver and maybe a 5 lb hammer to help conveince it?
    Certified Gearhead miro_gt's Avatar
    get a damn McDonalds burger, and try again
    if it's a factory turbo it might have a pin to keep it from being clocked, which means you'll have to pull the housing off and remove the pin (just fyi if it's an oem turbo)
    i would make sure u have all the bolts off first
    20 side of thangs
    compressor housing is off. all bolts out of the exhaust housing except two that the center section wont let move all the way out. i am gonna torch it up and see if i can get this sucker to turn.
    Blooregard Q. Kazoo turbosx©'s Avatar
    femalesaplenty
    buy a new turbo?
    I got dinner to goto.
    Senior Member Krazykouki's Avatar
    Ball Ground
    thats what I keep telling him. Get a new turbo. Hitting it with a hammer like some of you are suggesting is just plain stupid, have any of you ever worked on a turbo before?? His housings are cast iron and they will crack.
    I suggested heat, I will torch it up tomorrow for you, just remind me.
    Oh and if I get it off you owe me lunch, I will do it during lunch.
    No Homo.
    femalesaplenty
    if anything B. jus buy a cheap one off ebay for a temp setup.even if its an SS one
    Ball Ground
    Quote Originally Posted by SE-R_Killer
    Bad idea. If it blows it can tear apart his freshly built motor.
    No Homo.
    Gainesville
    Quote Originally Posted by MeanGreen
    i'm not sure if you can tell but i was being sarcastic
    2.3 Evo 8
    Guest
    1. Get a room at the Marriot hotel on the top floor.
    2. Open window.
    3. Drop turbo out window.
    4. If it doesn't work, repeat step 3.
    Ball Ground
    Quote Originally Posted by §treet_§peed
    I know. Its the other dumbass's who will actually try that and break their shit.
    No Homo.
    'Round These Parts
    ^ hahaaa!
    Damn Bradon, I almost wanna give you mine to drive*, you've been through it all.
    *no, not really
    Leisa and S. 4 Life NM?
    femalesaplenty
    i didnt mean for a permanet fix jus temp until so he can drive the car.unless he still gots to break in da motor.if thats the case check kat.org
