Results 1 to 18 of 18
Thread: D series concerns....
    Default D series concerns....
    When boosting a D series... which is more of a concern... How much PSI you are pushing... or how much HP the engine is making?
    oh yeah thanks for all the help with my noob questions
    EastCoastBoost
    Dunwoody, GA
    hey man, it all depends on what you are doing? running a turbo or supercharger???? they are to different styles of set-ups. let me know what your running style of D-series motor, and i'll let you know. i'm running a Jackson Racing Supercharger on my D16....
    I pmed you just in case you didn't know lol...
    both.
    10psi is ok on a T3 or T25
    10psi is NOT OK on a GT4088R
    whp just helps guess what the motor is making relative to turbo size. if you tell me your making 250whp at 5psi, then i assume you have a monster turbo. bevcause thats the only way a D series makes that kind of power, with a big turbo.
    you say your making 250whp at 10 psi, then i assume its a T3/T4ish setup.
    either way, Boost relative to hp output is what kills a motor. A d series we dont reccomend past 10psi or 230-250whp on stock motor
    Thanks for the more logical help Mr. Kidd
    MEGATRON 112480's Avatar
    Mobile,AL
    So what's your setup??????
    EBTEC
    EMMINO BUILT
    Allmotor K EK Hatch Coming Soon.....
    Cambodia
    I ran a t3 60 trim on my with 11 psi and untuned for 2 years until it spun a bearing...d16y8, heard its the most common with spun bearings. I loved the t3, it didn't have too bad of a lag and it gave me some good top end power. I still have that turbo and a manifold if you're interested =0). There's ZERO shaft play and the seals are still perfect.
    well my setup is going to be a turbonetics t3/t4 50 trim with the .48 A/R getting it up to the shop soon to get tuned and installed.
    Gainesville
    Mainstream Performance FOR THE MORTHER FUCKIGN WIN YO!
    Certified Gearhead miro_gt's Avatar
    is your motor stock ?
    I run 1 bar on my stock block with the 15G
    he has a stock motor, D15B SOHC JDM VTEC
    an no hes not running 1bar, an he will never run that much boost on a D series lol. thats dangerous as hell
    and Mr. Kidd should know lol... he did my engine swap and is doing the turbo install MSPi FTW Great guys over there so far as I've seen.
    yep, it is ... but it's fun as hell too.
    but then, you're suppose to realy know what you're doing in order to run that much boost on a stock D .. LOL
    EDIT: mine is daily driver too
    Quote Originally Posted by miro_gt
    any dyno #'s yet? very curious. thought about pushing mine a little further once i install my boost controller and larger map-sensor.
    nop. I just installed the 2.5 bar motorola sensor as well, cause I was running 1 bar on the stock one, and I can say the 2.5 bar works very nice. And the compensation for that one in the Hondata s300 matched the stock map sensor 1:1 in vacuum and in boost up to 10 psi. Gotta love that.
    so what I did was I went and tuned the car up to 16psi ... so damn, I'm happy. I don't drive at that much though, I keep it at 1 bar, cause it's not stable anyways (jumps up to 15 and down to 13 psi) ... Damn internal wastegate
    but honestly, I've calculated my timing precisely, so I'm confident in running 16psi. I know of one guy that did that much boost with streight 1deg/psi retard from the boost start, and he ran like that for 1 year, until one day he put some crappy gas and blew it. And I run 2 degrees less than him at that boost level When I get bored, I may run it at 16 psi ... oh well
    I think the car misfires form time to time, so I guess I'll pregap the plugs again.
    ah, hear this: I've almost maxxed out my RC440cc injectors, cause I'm running the stock fuel pump, LOL
    EDIT: of course it's gonna misfire .. I changed plugs yesterday, and the old ones measured 0.055 gap 30K turbo miles ago those were at 0.035 gap
    Gainesville
    hmm
    well Its all going down this tuesday so I will let you guys know what we end up with ! I can't wait to get my car running good and not have to worry about stuff lol but I guess that what you get for taking over someone else's project... oh well Its practically all mine now
