Results 1 to 15 of 15
Thread: Aluminum plating..
    Navy Recruit AgentEasy's Avatar
    Cobb
    Default Aluminum plating..
    anyone know of any companies that have 1/4" aluminum plating.. making a custon cooling plate for the rx.. any help would be nice..
    there i did it.. what'd you think?
    Drive-By Samurai SniperJoe's Avatar
    Somewhere out there
    You can pick that stuff up at Lowe's. 1/4" is probably a bit too thick, though.
    What if there is no tomorrow? There wasn't one today.
    Evolution Autodesign
    Quote Originally Posted by AgentEasyX8900
    ¼" aluminum would be crazy thick and very heavy for that area. It'd be pretty tough to bend w/o proper tools. I wouldn't go more than 1/10". Give the Metal Supermarket a call...think there's at least 3 around. The one I went to was on Pleasandale. We bought ½" mild steel plate I used to make turbo flanges w/.
    '06 G35 Sedan | 6MT
    Been There Done That DaX's Avatar
    newnan.ga
    0.040" will probably serve you nice. McMaster-Carr is probably the easiest place to order from. Do you have access to a brake?
    Cobb
    naw i'm cutting it by hand and i'm not putting louvres.. or whatever..
    Cobb
    Quote Originally Posted by SniperJoe
    no i need a bigger sheet..
    a cooling plate or just a shield?
    Cobb
    kinda both.. like i'm replacing the plastic shit under there but also hoping for the added affects of a cooling plate..
    under where?
    Cobb
    the motuh..
    the motuh..
    ohhh, under the engine...that'll hold heat in unless it has louvers or some sort of ventilation.
    Cobb
    i was gonna punch some holes in it with my hulk strength..
    Somewhere out there
    Agent, there are a couple of books on aerodynamics you should probably read before you start doing that stuff. Or at least, do a bunch of internet research.
    Cobb
    ok thanks man i was going to lolz
