Results 1 to 15 of 15
Thread: tranny problem?
    its all about the B's brwloco's Avatar
    Doraville,GA
    Default tranny problem?
    my car can not go into reverse(5sp), it fells like its blocked, everytime i try it won't let me... any idea wht it could be?
    97' Acura Integra GSR
    180 @ 9,000 RPM
    Belview Insane Asylum
    Every time? Have you tried putting it in 1st and then reverse? If I remember correctly, they share the same synchro.
    Doraville,GA
    i can go through gears but i cant get into reverse
    180 @ 9,000 RPM
    Georgia Muscle twinj's Avatar
    Da "A" Niccuh
    My car does that sometimes. I just put it in 1st gear and come off the clutch enough so that it roll like a 1/8 inch and then mine will go into reverse
    Where Am I
    ^^^same here, mine does that all the time....
    Doraville,GA
    yea just tried it ... didn't work
    180 @ 9,000 RPM
    aybendito deeze's Avatar
    Quote Originally Posted by brwloco
    have you stopped real hard while driving on reverse?? when this happened?
    does it grind?
    does it go in Rev. with the car off?
    I thought reverse is a non synchro gear
    maybe a reverse shaft gear is broke??
    i would lift the car and take a look underneath. it's possible the linkage is hitting something. i've seen this twice when customers brought in their car and i couldn't get it into reverse to get it off the dyno.
    Doraville,GA
    Quote Originally Posted by deeze
    does it grind?
    nope to all 3
    180 @ 9,000 RPM
    Doraville,GA
    im gonna lift the car up and see if its the linkage, if it is that what should i do, just mess around with it untill it gets in?... wow that sounds really wrong
    180 @ 9,000 RPM
    Doraville,GA
    ok its not the linkage, now i got a big problem it must be internal
    180 @ 9,000 RPM
    Macon
    I had that problem in a prelude I used to have. It all started when I shifted from 2nd to 3rd really hard and grinded a little. It only grinded one time That particular tranny only had about 40k miles on it so I know the syncro's werent gone yet. After that, It would not go into reverse. Sometimes if I put it in 4th and let the clutch out a little and then put it into reverse it would go. About 3 weeks after that started, 2nd gear went out. I believe the whole thing was related to that one grind. I took it apart and couldn't really tell why it would not go into reverse, everything looked fine.
    good luck with it
    Land Rover LR3 HSE
    ..and your point?? Whitebandit's Avatar
    Albany/road less traveled.
    Just buy another tranny.
    Doraville,GA
    Quote Originally Posted by Whitebandit
    yea that would be easy if i had money
    180 @ 9,000 RPM
    Ooltewah
    god i hate honda trannys
