Results 1 to 14 of 14
Thread: WTB DA front spindles or possibly whole brake swap!
    random guy's pops!
    random guy's moms cornhole!
    Default WTB DA front spindles or possibly whole brake swap!
    lmk what you got ,thanx
    dnwp
    random guy's pops!
    ttt
    dnwp
    LS/VTEC FTMFW!! SKUNK2GUY's Avatar
    lawrenceville
    talk to thechosenone he's parting out my old da it needs rotors but he should still have the cross drilled rotors i gave him you could get front and rear prolly from him
    YEAH I LIKE TO PARTY!
    random guy's pops!
    thanx!
    dnwp
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    Is your civic a base (4spd)? If not you don't need these unless you want to upgrade.
    boost wanted GermanMuscle's Avatar
    Duluth, GA
    you can also get them from a 94+ integra, they are the same as the da
    Senior Member mccoy1178's Avatar
    im partin out a 97 integra. i got the front and rear disk brakes if ur interested. $200 for front and rear if u pull, $250 ill pull them. lmk thanx
    Mccoy
    random guy's pops!
    i counted the splines on the hb and axles , not gonna match up
    dnwp
    ECEFC.com
    Quote Originally Posted by EF_SCOTSMAN
    double check cuz if you was using a dx or si tranny then it should work.
    random guy's pops!
    i'll check it out in the mornin!
    dnwp
    random guy's pops!
    dnwp
    Belview Insane Asylum
    DA knuckles will throw off your camber, FYI. And if you are going to do front and a rear disc brake conversion make sure you get the e-brake cables and the Proportioning valve.
    random guy's pops!
    i just tried to use my axles that came with the swap and they didnt fit in my hubs!
    dnwp
    Certified Gearhead Pavlo's Avatar
    Alpharetta
    Check Pull-a-Part they had 2 DAs with full rear disc swaps, no fronts though.
    Representing VWs.
