Results 1 to 40 of 57
Thread: FS/FT 89 Civic SI fully built new B18A
    Serious torque, In line 6
    Default FS/FT 89 Civic SI fully built new B18A NEW Price 2600
    New Price $2600, cannot beat that any where in parts. Also accepting trades. This is no part out, basicly the 2600 covers the engine and the rest of the car is free. Over $4000 is invested into the engine and I have receipts to prove it.
    Contact number 770-294-6359, feel free to call. 200miles current on engine, not even broken in yet.
    Make - Honda
    Model - Civic SI
    Year - 89
    Engine - B18A swap
    Mods - Fully built
    Vin - Upon request for serious buyers
    This car is fully built and ready for turbo install, you name it I have install it. Just got finished with the build, car is running very strong. I have all receipts for each and every part that was put in. Got another project to complete so I am selling this project and bringing out a bigger monster for the track this summer. Asking for a reasonable about but it is still OBO. And upon test drive, money has to be in hand ready to do business. Cash only, no checks
    Good- is listed below, full engine built with everything new except for Pre obd distributor, alternator, and starter. Everything else is brand new and installed. I have also spliced in OBD1 distributor harness, and have in place boomslang ecu OBD1 convertion harness and PR4 OBD1 ecu. So all you have to do is remove the pre obd Distributor and plug in the new OBD1 distributor that I will provide for you and the PR4 OBD1 ECU.
    Bads- Needs brakes, paint job. Cheap muffler, But is has 3 inch exhaust.
    I have some HR springs for the car 1.8 fnt and 1.7 rear. Haven't installed it yet.
    Engine Build
    Pistons and floating wrist pins – SRP 9.2.1 compression, Forged. 81.25mm
    Rings – JE gapless rings
    Forged Rods – Eagle Rods, Forged with ARP studs
    Metal head gasket – Cometic 81.5mm
    Cylinder Brace/ Block guard – BLD
    Arp fasteners – Head Studs, bolts and washers
    Timing belt – Goodyear
    Alternator belt - OEM
    Oil pump – Oem
    Water pump – Oem
    Timing belt tensioner – Koyo 93 Integra
    Spark plugs - NGK iridium
    Fuel filter – OEM
    Castrol synthetic blend oil with STP filter
    MSD 6A, MSD Blaster coil 2, MSD distributor cap part # 8299 with terminal connections 92-97 Integra. Not installed
    Spark plug wires- MSD 8.5mm. NEW in box not installed
    88-91 Civic B series swap Motor mounts and transmission mount with polyurethane inserts – Infinite-auto.com, comes with unlimited life time warrenty.
    Full gasket set - ACL
    FPR - AEM fuel pressure regulator
    Fuel rail – BDL high flow fuel rail
    Fuel gauge – BGM
    Exedy Stage 2 clutch and Exedy light weight flywheel 12lb (93 Integra LS)
    OEM Alternator, Tested at 14 volts
    OBD1 distributor and rotor button (92-95 Integra LS). new in box, not installed
    Pre OBD distributor (90-91 Integra LS)
    Oil pan with turbo return port (91 Integra LS)
    Magnetic oil drain plug – Golden Eagle
    Thermostat - OEM
    Marine battery box for trunk
    New battery, already relocated in trunk with box
    OEM new 93 Integra micro polished crank with bearings
    Intank fuel pump – Walbro 255lb/hr high pressure, new in box
    Polyurethane shift bushings
    88-91 Civic B series swap axles – Avid Stage 1 racing axles 250-400hp rating
    Right and left output shaft seals
    Skunk2 intake manifold
    Cold Air Intake
    550 RC injectors
    Machine Shop
    Head – Replace valve guides and valves, replace all valve seals/ rebuild head.
    Block – Bore/Honed the block .25mm over to fit pistons. Install and weld block guard, and shave down/deck block.
    Pre OBD to OBD1 Conversion
    OBD1 Distributor (92-95 Integra). NEW in box
    OBD1 Distributor harness (92-95 Civic) Already splice in, all you have to do is remove the pre obd and connect
    OBD1 O2 sensor harness and O2 sensor (92-95 Civic)
    Pre OBD to OBD1 ECU conversion harness- Boomslang.us
    PR4 OBD1 ECU (93 Integra non-vtec 5speed)
    Hondata S200 - Fuel MGT
    Attached Thumbnails Attached Thumbnails -07-21-06_1007[1]-jpg   -07-21-06_1008[1]-jpg   -07-21-06_1009[1]-jpg   -07-21-06_1010[1]-jpg   -07-21-06_1011[1]-jpg
    you dont need to know
    what shop did da work
    The motors looks nice as hell, can you PM me your VINs?
    Bump
    200 miles on engine, haven't had time to finish putting miles on it to brake it in.
    are u trying to part the interior on not? because if u sell the engine i would be interesed in buying interior pieces. LMK thanks
    yo clean out your pm box plz. also can u get some interior shots? Bump
    PM box cleaned
    Bump,
    Don Mon SiRed94's Avatar
    Morrow 30260
    clean engine...
    Vtecing is my HOBBY!!!
    Honda dealer
    you could eat of that...bump
    Bump, Offers are open. OBO on price or trades
    to the top
    SPACE WEATHER!
    Cecil
    So does this car run and drive? Would it be suitable whatsoever for a DD?
    v2.0 IndianStig's Avatar
    Sep 2004
    Gwinnett County
    trade me for my 1992 Honda Prelude Si plus cash on your part?
    it has 124k miles, 5spd, runs strong. but i'm ready for a boosted beast
    Sep 2004
    Gwinnett County
    Do you have any more pics man?
    bump for a ef
    Jonesboro/Stockbridge
    thats a clean ass ef.
    AKA "C@$HMONEY" vtecgsrguy's Avatar
    SOUTHSIDE
    BUMP FOR YA MAHNE! CLEAN AZZ MOTOR! GL WIT DA SALE!!
    Bump, Can work with anyone on the Price shoot me offers or trades
    SPACE WEATHER!
    Cecil
    Well hopefully I can get this on Monday.
    Sep 2004
    Gwinnett County
    here's the pics of my car man. you got any more of yours? you said you'd have them a while back.
    to the top
    Check your pms
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    good deal on this!
    Honda dealer
    resize pics
    Senior Member SE-Rious©'s Avatar
    p/med **
    Super bump
    up
    Bump for better pics!@
    bump for a good honest guy.
    white power!!!!!! .....1
    Bump, any offers
    ^ how about a barrel of used lexus parts and 2 used tires?
    bump for better pics/resize
