Thread: d16 turbo high idle
    Rednecks Everywhere
    Question d16 turbo high idle
    if i make any kinda of boost my car will idle around 1500 rpm i think it has to do with the map sensor but how to i solve this problem plus i think it sends it into a safe mode and if i turn the car off and restart it it idle's normal
    idle wouldnt be affected by the map sensor, its most likely your iacv or cold idle valve
    Rednecks Everywhere
    how do i fix this any idea?
    stockbridge
    is it tuned at all? or jsut a shade tree turbo setup?
    a little more info on your setup is required.
    1. what engine management are you using (stock inj fmu missing link, 450cc afc hack, larger inj w/ tuneable ecu)?
    2. what d16 do you have?
    3. any cel?
    4. how much deflection is on your throttle cable (none, 1/8", 1/4")?
    5. what throttlebody are you using?
    any other info you have will help in the e-diagnosis...more is better than not enough.
    Rednecks Everywhere
    well everything is stock and its the y5(hx) im running a greddy rebic 4 with 1 inj. @8psi but at 5psi it was fine i think like green91 said its the iacv but im not sure..no missing link yet but its on the way
    Certified Gearhead miro_gt's Avatar
    Quote Originally Posted by boostwizard
    what the hell is that ?
