Results 1 to 16 of 16
Thread: Engine removal help asap
    AKA Stock_dc2 torqlswonder's Avatar
    Exclamation Engine removal help asap
    hey i was just pulling my motor off an integra and i was just wondering if anyone could help me and tell me the best points to lift it from. where do i lift it from whatpoints reps will be rewarded for any help
    come on help me please im anxious. i called my boys who might be able to help me but no one answers
    Ohio asshole.
    Usually I pull my motors out from the bottom, engine cradle and all. Just because I don't have a cherry picker lol and I'd jack and block the car until I could slide it out. The times that I did have a cherry picker though I took the chain and bolted it to the transmission, and to the motor mount that comes out where the Timing belt is. Good luck though.
    LAWRENCEVILLE
    just call me dipshit!
    Hella stock member!
    your moms house
    Quote Originally Posted by jmmx258
    HOW DID YOU PULL IT UP TO GET THE BOLT THROUGH THE MOUNT TO PUT IT THROUGH THERE?? LAST TIME I CHECKED IF I PUT A BOLT THROUGH THE MOUNT, IT WAS ATTACHED STILL AND WOULDNT RAISE UP
    FUCK B&D COMMUNICATIONS!
    Sep 2003
    Not sure if the teg is like my eg, but there is a bracket on the front of the transmission I hooked one side of the chain to, and then I put a bolt through the chain in a hole on the back side of the head near the IM.
    Hopefully this helps, I know how frustrating it can be.
    Ohio asshole.
    Quote Originally Posted by b18hatch
    Put a jack under the motor with a 2x4 and pull the 2 nuts off and one bolt out of that bracket..unless its on an EK honda..then its 3 nuts, put a link down over one of the studs, and put a nut on it.
    Your post kinda confused me lol. I did this on honda's though....
    DC5-R
    Gwinett
    just get a tire, and drop the whole swap on the tire, then drag it out. Done deal after that.
    B Powered Mik2006's Avatar
    North Side
    u finaly get a car yet?
    cars
    integra 90 ls
    integra 92 gsr b20v turbo
    integra 00 ls
    infiniti i35 02
    __DailyGrind
    i am a formal jedi knight....i just use the force to swap engines
    LS/VTEC FTMFW!! SKUNK2GUY's Avatar
    lawrenceville
    i undo the moter mounts then hit vtec so hard the motor pops out!! lol!!! g/l yo! oh yea i'm serious!! if the car doesn't have vtec i loosen everything up and drive around till it falls out. hope i was of some help.
    lawrenceville
    did my method work?
    Quote Originally Posted by iloveapc
    did my method work?
    did you expect me to try it?
    Macon
    there should be some pull hooks on the engine already.... a lot of them come from the factory with them. If not, hook your chains up to where the motor mounts bolt up.
    Land Rover LR3 HSE
    Project DX
    Quote Originally Posted by Mik2006
    mik u finnally get some hp lol
    DOHC NO-TEC
    Senior Member PD code 805D's Avatar
    black hollywood ga
    if youre looking for a easier way, just take a sawzaw and cut the front assembly off and unbolt and there you go no jacking or lifting...Lol but only do this if you dont need the car.....
    need CA$H? I WILL BUY YOUR STUFF OF VALUE.... PM ME WHATCHA GOT!
