Thread: D16a6 to DOHC zc motor?
    random guy's pops!
    random guy's moms cornhole!
    Default D16a6 to DOHC zc motor?
    i am goin to buy a DOHC zc motor to replace my D16a6 , will i need to get a new ecu , halfshafts , wiring harness , etc.... please inform me of all the things i would have to change ! thanx fellas , reps will be given!
    dnwp
    ®anj-♠ ranj's Avatar
    i don't think u would need a new ecu, i'm not sure about the rest though
    random guy's pops!
    thanx! unfortunately......You must spread some Reputation around before giving it to ranj again.
    i'll get ya when i can bro!
    dnwp
    in a paint booth
    does the dohc zc have a half shaft i dont think it does but i havent seen one in forever and i dont think you have to change the harness unless you hatch is only a dpfi and you convert it to a mpfi
    Macon
    Quote Originally Posted by ranj
    you dont HAVE to have the ECU that goes with the ZC engine, but the D16A6 ecu does not have the correct fuel map. If you want the full power of the ZC swap, go ahead and get the correct ECU. The compression of the ZC is a little higher than the D16A6, and the cams are larger... Also consider swapping the USDM CRX Si final drive into the ZC tranny, since it is lower (4.250 in the Si, 3.888 in the stock ZC tranny). If I remember correctly, the final drives are interchangeable. someone correct me if I am wrong. With the Si final drive, the tranny will be close in specs to a gen 1 B16A tranny that came in the JDM CRX SiR VTEC. good luck with it!
    Land Rover LR3 HSE
    stockbridge
    aww boo. u wont gain performance from that swap. when i first got my crx si d16a6, with intake, i beat a dual cam zc wit hintake header/ exhaust, 40 -120..of course all cars are different, but a zc isnt a good dual swpa IMO. but i dont know the circumstances.
    curious on why u are deciding on this swap? or is it jsut u found a good deal ect? ..
    not flaming, ive spoken with this man alot before, jsut curious.
    cough LS cough
    Gainesville
    lol casey
