Thread: Transmission Flush on GSR
    Default Transmission Flush on GSR
    i am wanting to flush/change my transmission oil on my DC...any pointers will be appreciated
    Is an auto or manual?
    If manual then use GM Synthetic Synchromesh (3 QTS I believe), you can also get it at O'Reillys but it'll be Pennzoil brand instead of GM; which you'd have to get from the dealer.
    If auto then just use Dex 3 or whatever it uses.
    Certified Gearhead bluuuurr's Avatar
    Oct 2003
    Monterey, CA
    if it's a manual, the car has to be level when you put fluid in it
    honda oem fluid ftw
    its manual...i dnt have an o reillys parts store around here...carquest, advance, autozone and napa.
    i read somewhere that the car is suppose to be level when draining the oil??
    I don't about being level when draining the level but it might possibly let more oil out which allows more new oil though but yes make sure car is level when putting fluid in tranny to make sure there is enough or not enough when it starts to come out of the drain plug on the side of the tranny
    gotcha thanks for the info fellas
