Results 1 to 21 of 21
Thread: so who wants to fix my stereo??
    georgia
    Default so who wants to fix my stereo??
    i have a 96 t-bird i just got in a trade and it has a nice jvc head unit and a spl 800 watt amp and a pyramid 1600watt amp and to kicker comp subs in a kicker ported box. the subs are good and so is the amp but i cannot get any real sound to come out of the subs damn near nothing you can only feel it sometimes if you touch the speakers. i put in a diffrent sub and it does not work at all.the amp gets power and im not sure what i need to do to get it to work.the previous owner said it just stopped working so he put in the pyramid amp and nothing and that amp is new. any advice would be great i would be willing to bring it to a real shop to get the job done re wired new amp whatever.... let me know....
    yes i am....
    ......................... con's Avatar
    75 South......
    you checked the speaker terminals? One of my subs vibrated the wire from the speaker to the terminal loose after about a couple years of use. I thought the sub was blown and replaced it. same thing, no sound. Then I found the terminal problem, but only after I had trashed the 2.5 yr old original.
    old school fool Allstar3.8T's Avatar
    Loganville Ga
    Pyramid amp....hmmmm. There is a bad signal somewhere. Maybe an RCA, maybe a even power , like blown fuse, that didnt completely break, and still trickles enough power to work, but not well. My guess honestly is the amp isnt good. New or not, you get what you pay for, and Pyramid isnt exactly high end....its flea market.
    Try borrowing another car w/ working subs, disconnect thier sub box, wire yours in. This will tell you amp or subs.
    Greg
    86 Buick GN
    07 Passat Wagon
    01 Frontier
    Senior Member | IA Veteran DJ XtRaKŠ's Avatar
    Apr 2001
    Roswell
    check your RCA connects at both the headunit and the amp...also make sure positve is to positive and neg is to neg...that can cause some problems...if not...i unno
    IA OG
    georgia
    i know pyramid is low quality the spl amp is decent. i check the connections in the box and the back of the cd player. i will check for a half broken fuse now and try another set of rca's
    yes i am....
    Apr 2001
    Roswell
    put some spunk in the amp...thatll give you MORE POWA!!!!!
    IA OG
    georgia
    Quote Originally Posted by DJ XtRaKŠ
    spunk did the trick, hahaha.it was the amp wire on the battery it was loose but tight enough to give the amp power but would cut out with any voulme.so now its bumpin!!!!!!!!!
    yes i am....
    Loganville Ga
    I was close, typically a signal is on or off, but power feed/ground is a biggie. Nice find and fix!
    Greg
    86 Buick GN
    07 Passat Wagon
    01 Frontier
    Apr 2001
    Roswell
    SPUNK FTW *******!!!!
    IA OG
    (oo=[][]=oo) slowrolla97's Avatar
    Marietta GA
    wth is spunk???????????
    i am dumb sorry
    240atlanta.com
    Apr 2001
    Roswell
    Quote Originally Posted by slowrolla97
    i am dumb sorry
    you must not be american...
    IA OG
    BadAssNinjaTrunkMonkey
    Tell the shop that Ryan told you to call.
    Apr 2001
    Roswell
    MECP.....BWHAHAHAHAHHAHA.......ok
    IA OG
    formerly ATLS2K .....'s Avatar
    in your womans meat curtains
    MECP...lol ...so what color are the grips on a left handed avation snip.......
    --TEAM FUCT OG--
    07' moomba outback v
    02' Xterra
    01' IS 300
    Cumming, GA
    a) red
    b) yellow
    c) green
    d) blue
    Hiram, GA
    ohh ohh I know
    (I own 2 pairs actually)
    Apr 2001
    Roswell
    actually i think left is red isnt it?
    IA OG
    yep... but that is the most useless question on the test... actually the test is worthles in my opinion.
    --TEAM FUCT OG--
    02' Xterra
    01' IS 300
    Apr 2001
    Roswell
    who gives a fuck...look at the damn things and figure out which way they go! lol
    IA OG
    was up
    Hiram, GA
    actually left is green, red is right and straight is yellow
