Results 1 to 15 of 15
Thread: map sensor?
    Default map sensor?
    My map sensor keeps kicking my check engine light on cause it keeps reading to much boost. I was wondering if y'all could help me out with this?
    Jul 2003
    Atlanta Centennial Park
    you need to get a different map sensor like a GM 3 bar or MSD 2.5 bar
    Stock map sensor is only good for 11psi
    you should never run more boost that what your map sensor can see or you WILL BLOW something up
    -www.usedbarcode.net
    give us more info on your setup: car, mods, engine management, etc.
    sounds like you're running stock ecu with boost which=trouble.
    get a socketed/chipped ecu and get it tuned.
    let me know if i can help.
    HONDATA DEALER/TUNER
    NISSAN REALTIME-NISTUNE
    have 98 automatic civic with d16y8 with custom mainstream kit. It was tuned using the VAFC by Charles so he knows ins and outs. I am running 8psi.
    thanks mike always helpful!!!
    new missing link needed
    that is what i am leaning toward cause i do not have one. Would you happen to know someplace that i can get one?
    Jul 2003
    you can make one
    can i get some details on that mike. Cause i know its similar to and oversize metallic gasket. Seen them on ebay.
    Jul 2003
    I have some at the shop
    Jul 2003
    Man i didnt even notice this was in your forum , my bad, i thought this was in the BOOST forum. i just checked NEW posts and replied. James you can delete my comments
    I will swing by the shop and pick one up. I won't be able to get up there until next saturday cause of work schedule. :goodjob:
    just let me know because we are closed on sat now, but i will have to make sure someone is here for you.
    what are the new hours for shop?
    known as Charles
    Douglasville
    m-f
    m,w,f 10-6
    t,th 10-8
    Main Stream Performance
    Don't make excuses...Make Power
    Digital Box Tuning (Scttydb411)
    www.mainstreamperformance.com
    MSSracing.com
