Thread: D16z6 head bolt question...
    Senior Member mikesEK's Avatar
    over yonder
    Default D16z6 head bolt question...
    Doing a head for a friend & the last person to do the head must have toured bolts down to like 200lbs ((i had to use pipe in ratchet just to remove them)) so any way one of the holes is a little stripped & after checking it out it looks like I'll be ok IF i CSN find another head bolt that's about half an inch longer!! Dies anyone have any ideas????
    Is there another head that uses same thread pitch BUT is apprx 6.5 inches long?
    **the one i removed is right at 6inchs**
    if someone has something laying around i can use that would be killer
    OR
    one of the gurus tell me where to buy one would also be killer
    thanks y'all
    mike 770-309-3487 (call txt)
    Attached Thumbnails Attached Thumbnails -image-jpg
    PawnShopMike
    I miss-spell big words freeqwentlee thanks Dekalb Co skhool systems
    Projects
    What if you just didnt use the washer or a thinner one ?
    over yonder
    No... Wouldn't work.... I need another half inch or so
    PawnShopMike
