- 91 EF engine swap HELP
- Rep Power
- 0
I have a few options here and I need some general information or advice. Thanks in advanced.
I have a stock 91 EF DX, I am wanting to avoid a wiring swap I know there are OBDO LS, B16, ZC (DOHC) and the standard D15's.
Fisrt off is there a way to convert a D16z6 to a OBDO by using a an OBDO distributor and intake manifold?
If not I am looking into putting a ZC swap in since they are fairly cheap. This is my DD and I am not looking to create loads of power I am just trying to get it back on the road ASAP and for the most affordable and easy way. The only reason I ask about a Z6 is because I have a new head and can get a block for cheap but it will need to be rebuilt.
What would I need to put a ZC in and is it the best route for the money the whole swap minus mounts can be had for around 1K.
- You may not post replies
- You may not edit your posts
Forum Rules
