D15z1(has the vtec-e) engine in a 98 civic. Me and my buddy has came to the conclusion that in the civic they have kept the obd2 wiring harness and obd1 conversion harness. We've sodered the dizzy so it plugs straight into the wiring harness (because we had to replace the dizzy) . its a z1 head and block with a jdm d15 intake manifold, we have a z1 distributor with a obd2 distributor wiring harness soldered together.
We were doing a head gasket on this car originally that had been sitting for about a year, after replacing the gasket, we changed the oil and filter, new spark plugs in, new timing belt, kept the old spark plug wires, kept old rotor cap, started out getting weak spark, changed the ignitor(screwed up the original one up), so we bought a remanufactured dizzy thinking that was the problem. Now we have no spark at all.
We have compression, fuel pump primes, main relay clicks twice.
What ive tried/checked.
Known good dizzy cap and wires off of a d15b7
Spare ecu(p28 5 speed, his car is also a 5 speed)
Checking fuses under the dash and under the hood. fuses 9, 13, 15, 18, 24, 27, 28, 33, 24(all that have any thing to do electrically) except Fuse 31 has no power (ECM/ PCM, pgm-fi main relay, intergreated control unit)
Re-check mechanical timing.
No CEL code
Changed ECU's
Checked and cleaned all 3 grounds.
Distributor terminal A: 12.15v -- terminal B: 12.15V -- coil spring 12 volts
compression check dry : 4(110) 3(90) 2(95) 1(110)
Ignition switch all checks out at 12 volts and above.
Fuse reference.
