Results 1 to 8 of 8
Thread: 1993 Honda accord evap problem. not passing smog
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    Quote Originally Posted by SlayrPhoenix View Post
    the timing seemed ok. but we will check it too. i changed the spark plugs and cleaned the air filter and that was a major IMPROVEMENT from what the car was doing a few hours before. my uncel said we need to adjust the idle up cus its idling at 5k and i tried moving the distributor but it wasnt doing anything. can u tell me where the idle adjustment screw is so that we can adjust it from that?
    The throttle body has an idle adjustment screw on the front but leave that one alone. I would adjust the screw below the throttle butterfly. Open the plate just a little
    98 Acura Integra LS-DD
    ??????????????????-project
    Unknown SlayrPhoenix's Avatar
    Feb 2012
    Gardena, California, United States
    ok the idle problem is fixed now. car shud be fine and pass smog if not the o2 may need to be changed and/or the egr will need to be replaced/cleaned but i think it shud be good now. thank you very much for the advice. if i run into any more problems i will not hesitate to ask
    Slayer Phoenix
Tags for this Thread
