Thread: OBD2 1998 Civic Check Engine Light Code 15
    It's all about JDM.
    CA to GA
    Default OBD2 1998 Civic Check Engine Light Code 15
    Alright guys. Hows everyone doing? So long story short, I just recently purchased a JDM ZC non vtec motor, and swapped it into a 98 Civic DX. I did the CKF Bypass Trick to trick the Ecu in thinking the JDM motor has a CKF sensor on the oil pump. All is running good, but only for a short period of time. I say about 10 minutes every time after I crank the engine, the engine idles weird and fluctuates. So after a few days of trying to diagnose the problem, the Check Engine Light kicks on for the first time. It says Code 15. Anyone ever had a Code 15; any advice on how to diagnose code 15? Supposedly it has do with the Ignition Control Module. But could it be something else?
    I won't advertise because I'm not paying to
    Douglasville
    Swap the ignitor from the other dizzy
    It's all about JDM.
    CA to GA
    I only have one distributor. The Jdm motor didnt come with one. But im going to test the ignitor and ignition coil inside the distributor.
