Quote Originally Posted by 2000ex View Post
i would first check and make sure you have the right bulb harness plug into the right headlight. the watts on each bulb may be different, high beam may need more than low beam, if its swapped, the bulb wont work. just my 2cent
check fuse, and wires in the engine bay. make sure none are rubbed together.
last thing i would check is the switch. they do break over time.
the plugs are in the right spot and the fuses are fine. i understand that the left low beam not working is probably because of loose wires or something simple (since the passenger side still works) but i'm not sure where to start on the high-beam problem, the lights dont turn on but the symbol on the dash won't turn off
