Results 1 to 13 of 13
Thread: 94 civic w/ a b20b radiator problems
    Swap king james497's Avatar
    Jul 2009
    N. Philly
    Default 94 civic w/ a b20b radiator problems
    I have no leaks but every time I start the car the radiator fills up with air, Brand new head gasket so I dont know what the problem is. thanks in advance
    b20b is in!!!!
    b20b vtec coming real soon!!!
    Jul 2009
    N. Philly
    new radiator,cap and thermostat
    b20b is in!!!!
    LAWRENCEVILLE
    fill it full of coolant start it up with out the cap, Then rev it up a few times if coolant blows out the radiator you have a headgasket issue.
    Hella stock member!
    Jul 2009
    N. Philly
    ok
    b20b is in!!!!
    Jul 2009
    N. Philly
    I did that and when i started it coolant blow out so i filled it while it was idling and rev it and coolant would just overflow the radiator not really blow out
    b20b is in!!!!
    Jul 2009
    N. Philly
    and the car when in idle it starts to over heat but when you drive it,it goes back to regular operating temp
    b20b is in!!!!
    Super H8ter Starrfire's Avatar
    Yeah you've got a compression leak into the coolant system.
    My line of work
    www.internationaljets.com
    Jul 2009
    N. Philly
    so how do i take care of that?
    b20b is in!!!!
    Well you need to be sure first. Take out the spark plugs and see if there is any noticeable coolant in the cylinders. Also another way to diagnose it is to run the car for a minute, take out the spark plugs and put a couple of paper towels over the spark plug tubes. Look for condensation on the paper towel. That would be an indicator of moisture in the cylinder.
    My line of work
    Jul 2009
    N. Philly
    well it is a compression leak cause at the gas station i let the air out and went to start the car, the car wouldn't start so i went back to the radiator and the hose were filled back up with air so it is a compression leak. how to fix? a new head gasket? can you put a head gasket on wrong and cause this problem?
    b20b is in!!!!
    barrow county
    Air is leaking pass the headgasket into the coolant system.
    Probably should make sure the head isn't warped. Then get it decked if it is. Then get a head gasket and put it all back together.
    My line of work
    Jul 2009
    N. Philly
    the head only been on for two months after having a valve job and resurfaced
    b20b is in!!!!
