ok this should be my last question on all this, all of the wires match except for 2. i think they would go together and all would be fine but i want to be sure. on the obd-0 plug there is a white wire that goes to PGMFI/ ECU so i get that one. On the obd-1 dizzy it has a yellow/green wire that is the ignition input signal and goes straight to the ecu, almost like the pgmfi wire does. i'm wondering if these need to be wired together of if it needs to be different. all of the wires match for all the sensors just the wires are different colors which is the easy part. i just don't want this one wire to screw things up and i want it in the right place. any help would be greatly appreciated so i can finally turn this car on!!!! BTW REPS given to good answers as always. i know somebody knows this. usually i would be confident in it but i scratch my head. both dizzy's are 9 wire if that helps and they all have the same sensors it's just those 2 pesky wires!!!!!!
BTW we do have the conversion harness and an obd-1 ECU so i know it needs an obd-1 dizzy to run.
