Results 1 to 8 of 8
Thread: Torque Damper question
    Norcross
    Default Torque Damper question
    Thinking of buying an NRG torque damper. Someone told me that its not good for the car, any truth behind this? also, the car is a 92 civic with B series motor. So should i get the torque damper for a 92-95 civic or 96-2000 civic? thanks in advance n reps for replies
    Norcross
    still wondering
    its got a blow dryer jdmDC20's Avatar
    Apr 2010
    L'ville
    nothing really wrong with the torque damper... more for cosmetics. if you're really worried about motor torque issues you should look into getting just a rear hasport mount with your desired stiffness.
    i used to have one on my type r motor that was boosted on 20psi... when i took it off i couldn't tell ANY difference.
    You do not need a torque damper unless you have a toque monster for a motor! Useless and waste of space!
    Yeah couldn't really say anything good or bad about those things. Except if it is for cosmetics then you need to keep it clean because it will start to rust.
    Custom Tuning By Daniel Willie.
    Parts, Fabrication, Race Car Prep
    770-319-9605 or [email protected]
    ATLien ATLRoAcH's Avatar
    Mar 2010
    Northside of ATL
    If your just wanting the motor to be stiff than I would just go with some urethane motor mount inserts to start with. If that doesn't satisfy your needs I would do what the other poster said and get some stiff motor mounts. Those inserts help a lot because they go in the vibration mounts that are usually broken. They fix them if they're broken and stiffen them up because they fill in the holes.
    Senior Member civicturbo10's Avatar
    those aftermarket motor mounts sux b/c all of the ones i've seen vibrate the steering wheel at idle. If no care, i say go for it. My DD would never have those mounts.
    Honda - supplying products of the highest quality at a reasonable cost. Member of the high mileage club.
    BODHI - "whats the lowest you will take" then dont even bother posting in this thread! i dont have the time wasting on fuckin dumbfucks who dont know how shit works -- which is me, selling a phone and expecting someone to buy it. At least have some balls to tell me that youre too cheap to buy or say - fuck shoot me a pm if youre too embarrassed
    Mar 2010
    Northside of ATL
    Yeah that's true. Those stiff mounts will make your car vibrate pretty bad. If you just use the urethane inserts it's not that bad because they don't stiffen all the mounts but you will still vibrate some. Mostly just at idle like you said.
