WHY PAY EXTRA CANCELLER KIT IF THERE IS ONE HID KIT WITH BUILD IN ALL PART
CALL FOR MORE INFORMATION AND PRICES FOR IMPORT ATLANTA MEMBER : 678-407-4983
3500K GOLDEN COLOR $149 SET
8000K DIAMOND WHITE $139 SET
10000K CRYSTAL BLUE $139 SET
12000K VIOLET BLUE $139 SET
We have H1 H3 H4 H4 BIXENON H7 H8 H9 H10 H11 H13 H13 BIXENON 9004 9005 9006 9007 9007 BIXENON& 9008
We have 4 different colors available (GOLDEN COLOR, DIAMOND WHITE, SKY BLUE, & VIOLET BLUE)
H1 GP Thunder 8000k 35W
8000K
35W
High Intensity Discharge Lighting System
Xenon Diamond-White 8000K HID Conversion Kits
Super Diamond White
Everything is Included to Complete for Installation
Our GP Thunder 8000K HID kits are much brighter, whiter and prettier than any other HID bulbs you"ve ever seen. This is the best HID Kits you can own!!
ISO 9001, 2000, CE 13 Certified
H1, H3, H4, H4 Bi-Xenon, H7, H11, H13(=9008), 9004, 9005, 9006 and 9007 are available, and please let us know which model you need with your payment.
Resellers are Welcome!!
H.I.D Conversion Kit can generally be installed into the car that uses conventional halogen bulb headlight and has several advantages over halogen bulbs:
More light output. A 35W HID light source produced up to 3 x the lumens at the light source when compared to a 55W halogen bulbs.
Violet white light. The color temperature of HID lighting more closely approximates the color temperature of natural daylight than does a halogen bulbs, which appears yellowish.
Greater visibility. The combination of more light output and whiter color make for better visibility in most night time driving conditions.
Longer Life. GP Thunder HID lamps will last, on the average over 5 times as long as halogen bulb.
Easy Conversion. HID Conversion Kit is simple and easy to substitute for standard halogen bulbs.
Tests. Passed all of relevant environmental tests including CE, e4, DOT(pending). Radiated and conducted emission meet CISPR D/Class3, and Satisfy SAE and ECE
Mechanical Testing: Passed Thermal and Humidity Cycling, Vibration, Shock, Water Jet, and Dust testing.
Design: HID conversion kit, GP Thunder is design for retrofitting HID headlamp system for the halogen housing
Features:
No cutting and re-wiring required for entire installation.
35W. Xenon Gas Filled HID bulbs. No Filament
8000K color temperature. More light output
Highest quality
Produce Super-White light and more intensity of lighting. Please see the pictures how brilliant it is.
Easy to installation (20~40 minutes for a beginner)
CE Approved
One HID Kit contains everything you need (no need to buy anything else):
HID 35W bulb. 2 bulbs.
Warranty: 1 year warranty
