Thread: my headlight and dash lights arent working
    i <3 asians
    Default my headlight and dash lights arent working
    ok my headlights and dash lights on my 86 corolla arent working they were working fine and then i started the car they came on and then when i was going down the road and they just shut off and i got out checked the fuses and they seem fine. but the gauges still work the lights just arent coming on. my brake lights still work so, yea if anyone could help thanks
    Super Dave Z U L8R's Avatar
    Roswell
    first see if the bulbs are getting power going to them, if they are and they won't come on then the bulbs are bad, if they're not getting power then trace the circuit back, which you'd then check the relay, if still no power then you'd check the fuse (could be fuse then relay but you get the idea) then if still you get no 12 volts then you go to the source or "request" which would be the headlight switch. then you'd try known good headlight switch. could be a lot of things, but i'd lean towards corrosion being the culprit being that the car's pretty old.
    AE86 biotch!!!
    Take a look at the name of this site.
    Yeah it's probably corroded to hell.
    Sorry for threadjacking but what you got done to it?
    AE86 DORIFTO
