Results 1 to 16 of 16
Thread: 93 240sx help
    Default 93 240sx help
    i have a 93 240sx coupe
    ok today when i started it up today it just stoped going into gears like it wouldnt go into and really but befor today it shifted awsome the clutch gripped awsome but the throw out bearing was bad and it never grinded wat should i do ?
    Gainesville
    go have your tranny looked at...cause it sounds like you fucked it up to where it will not let it take pressure of to allow you to change the gears...but the way you made your statment confusses me on exactly what you mean...
    Banned SE-Rious1's Avatar
    WINDER,GA
    check the clutch fully make sure it is ingageing and does it not go into ger when cars not running ?
    Drifter/Kneedragger
    Buford, GA, USA
    more than likely leaking slave cylinder not letting the clutch disengage. check the fluid in the clutch master cylinder to see if it's low and if it is look under the right side of the car on the bellhousing to see the slave itself.
    Certified Gearhead bluuuurr's Avatar
    Oct 2003
    Monterey, CA
    hold the clutch down in neutral, hold the motor at about 3k rpm, and try to put the car into every forward gear.. if you can't, your pressure plate is not releasing.. which means, no pressure (slave cylinder)
    Marryetah
    You should sell it to me.
    Gainesville
    haha or me...
    Super Dave Z U L8R's Avatar
    Roswell
    i concur with hipsi, clutch slave most likely
    its fixed now and sell what to yall
    Quote Originally Posted by santacruz77
    The car
    - 2011 BMW 535i M-Sport - BMS Stage 1
    - 2003 TL-S Totalled
    - 2004 TSX - A-Spec wheels
    - 1991 S13 RB25DET S2 - sold, and missed
    how much you wanna give me for pm if your really want it
    My Spoon Is Too Big! Flip's Avatar
    what did the problem end up being?
    ugh i just put a new clutch and presure plate in and it fixed it all good as new
    Gainesville
    ya i kno
    maybe it was your clutch slave...............................?
