Cool well yeah i just want to make sure i get right part. Did you know of way to find out if car is cali spec? Can i get the air/fuel sensor at the toyota dealership also?
Oh let me ask u this if this is dumb question u can smack me, but if the car has air/fuel sensors does that mean the one on the front of manifold will also be air/fuel? Reason i ask is cause there is factory on on that and i got the part number off that one just in case it was needed. The part number on that on is 89467-41010 so i guess what iam asking is if say they both require air/fuel then that should let me know since it is part from factory. Do you see what iam getting at?
			 , and don't use cheap ass bosch universals that you have to wire in unless you know how to do it #1, #2 if you changed the correct sensor you probably didn't wire it right, you can get a denso oe replacement for not that much #3 the problem may not be the sensor you could have a damaged wire or short in the heater circuit....good luck
