- ok, i need help
ok, i need help
ok, so i have this d16y8 mani thats ported sitting in my garage. i took it to a shop to see if they could throw it on my d17. yea. ok so i need to drill the holes to match the gasket for the d17. fine. then i need to reposition the TB onto the y8 manifold. i have the TB from the y8 too. i think they are the same thing too. not sure. then re-wiring everything.
anyway, i would need a d16 fuel rail. i have no fuel return line. the shop guy suggested to plug the return line on the fuel rail, and just do it like that. my question would be, can i use an RSX fuel rail with the type S injectors. i know the injectors fit on the d17 fine without modification, but idk bout the rail. and does anyone know what other fuel rail would work on the d17 besides the d16, cause if i can avoid having to plug a whole then ill take the opportunity. thanx!
- ok, i need help
- You may not post replies
- You may not edit your posts
Forum Rules
