- ICS Idle Control Sensor
360HP @ 21psi SOHC
- Rep Power
- 22
i need the wiring diagram for the ICS "Idle Control Sensor for a 93 Del Sol
- Rep Power
- 22
ECU Pinouts
color legend: solid or solid/stripe color
A
Terminal Color...........Description
1 BRN.............Injector 1
2 YEL.............Injector 4
3 RED.............Injector 2
4 ORG/WHT.....VTEC solenoid
5 LT BLU.........Injector 3
6 ORG/BLK.......Heater Ctrl (H02S)
7 GRN/YEL.......Fuel Pump ctrl
8 GRN/YEL.......Fuel Pump ctrl
9 GRN/WHT .....Idle Air Ctrl Valve<--------------------
10 blank
11 blank
12 YEL/GRN.......Rad Fan ??
13 GRN/ORG ......MIL Code Light Ctrl.
14 blank
15 BLK/RED.......A/C comp.clutch relay or rad fan if yel/grn
16 WHT/YEL......Altern. Output
17 blank...........(AT)
18 blank
19 blank...........(AT)
20 RED.............EVAP
21 RED/GRN.......Ignit. Output Signal
22 RED/GRN.......Ignit. Output Signal
23 BLACK..........Ground
24 BLACK..........Ground
25 YEL/BLK........Power Input
26 BLK/RED........Ground
B
1 YEL/BLK........Power Input
2 BRN/BLK........Ground
3 blank............(AT)
4 blank............(AT)
5 BLU/RED........A/C req. input
6 blank
7 PNK/BLK........upshift light (CX only)
8 blank............(P/S) pres.sw
9 BLU/WHT.......Start Input
10 YEL/BLU.........VSS
11 ORG.............CYP/p sensor
12 WHT............ CYP/m sensor
13 ORG/BLU........TDC/p sensor
14 WHT/BLU ........TDC/m sensor
15 BLU/GRN........CKP/p sensor
16 BLU/YEL..........CKP/m sensor
D
Terminal Color.......... Description
1 WHT/BLU ........Battery Input
2 GRN/WHT.......Brake Swtch
3 blank............(KS)
4 BRN..............Diagnostic (timing)
5 blank...
6 ORN/BLU.........VTM/VTPS
7 LT BLU.........Diagnostic (data link)
8 blank
9 PNK.............Altern. FR sig
10 GRN/RED........ELD Input
11 MINT GRN.........TPS
12 blank
13 RED/WHT .........(ECT)
14 WHT/RED.......... 02 Sens Input
15 RED/YEL...........IAT input
16 blank
17 WHT.............MAP Grnd
18 PNK/GRN
19 YEL/GRN..........MAP Ref.Volt
20 YEL/WHT.......... Ref. Voltage
21 GRN/BLU .........MAP Input
22 GRN/WHT ........Sens. Ground
these maynot all be right but the one u need is (got it from some site)
below shows where the pinouts are IGNORE THE YELLOW AND RED SHIT
- You may not post replies
- You may not edit your posts
Forum Rules
