Thread: ECU help
    360HP @ 21psi SOHC TBoDelSol's Avatar
    Italy
    Exclamation ECU help
    i need some help with my ECU as you may of read b4 my car died and i charged the battery and my car would just turn over but not start. I found out that im not getting power to my ecu/ not sending power to kick the main relay.
    I have Checked:
    Battery
    Starter
    Ditributor
    Ignitoin
    Replaced the ECU with 2 different ones
    Replaced teh Main relay with 2 different ones
    Check fuel pump
    Replaced Fuse board
    2.0vtec
    Snellville, GA
    if you still have not gotten the car running, your welcome to bring it by the shop for us to look at. either way, the best thing to do is get it to a shop. it would be pretty hard for anyone to fix the problem without looking at the car and checking things. it looks as if you have gone over the main things, but a someone at a shop may know something or be able to try something you have not thought of or know about.
    Mahdavi Motorsports
    770-923-1550
    04 S2000 Turbo
    NDRA turbo 6 champions
    Nations fastest auto mkIII Supra
    RISKY RISKYB's Avatar
    athens
    sounds like a short somewhere
    You only live once, maybe twice if you use the e-brake!
