Thread: overheating
    TeAm ToTaLMaDnEsS .. JuLiaN_TM's Avatar
    SaNdY SpRiNgS / MaRiEttA
    Default overheating
    ok i got a 95 civic with gsr swap and its overheating big time . there are no leaks and coolant level is fine . i even put the fan to stay on all the time and removed the thermostat and still the needle goes to the H on the gauge , dont know what else to do or what it can b . any suggestions would b apreciated
    revolution big mac's Avatar
    clogged radiator?
    Sohc Me Beautiful geezy's Avatar
    With Your Mom
    Quote Originally Posted by big mac View Post
    clogged radiator?
    ah u beat me to it
    x2
    turbos
    headgasket...............maybe
    TOO BIG
    is there fluid boiling out of the reserve can. is 1 rad. hose staying hot and the other cold.
    sandy springs
    1. replace thermostat, and remove jumper from fans
    2. proper bleed the system to ensure there are no air bubbles
    3. run car, make sure fans are kicking on and spinning at adequate speed
    4. use a gauge to check temperature throughout radiator.........varying temps=clogged. A small variation is normal
    5. leak down test to check headgasket
    thanks for all the help it was the temp sensor that was sending wrong info , so it wasnt really overheating but the gauge would show like it was hot .
