Results 1 to 18 of 18
Thread: Overheating Problem !
    Mar 2010
    Default Overheating Problem !
    ok the other night i raced a guy. on the way home my car started to go past normal operating temp. today i looked under the car and right where the oil pan is, on the ground was water/antifreeze. so i filled up my radiator, cranked up the car with the rad. cap off and water was coming out of the radiator, along with air bubbles. can anyone tell me what the problem is. Thanks.
    Senior Member SLow_POke's Avatar
    WEST_SIDE
    uh-oh... you will more then likely have a blown head gasket If u have* burped the system
    Mar 2010
    ok well. i drove the car today. it drove fine. stayed at the right temp. the whole time. i also went into boost and it stayed the same. can anyone tell me what happened
    God gave you a warning for being gay and racing on the street.
    IA Member CodeRED-MVBC's Avatar
    On a train, In a plane!
    hahahahahahaha your right man. its a risk man especially if its your d.d.
    yuuummmyy
    Dec 2008
    water pump
    "Bacon And Cheese"
    air in lines, head gasket, or pump
    Mar 2010
    um like u have never raced on the street.
    IA's Pedo-cord tdurr's Avatar
    Fayco
    Quote Originally Posted by ej1boy93 View Post
    dont ever say u raced on the streets unless ur in the kf otherwise ppl will bitch and moan. but check wut barefoot says. hg, wp, and possibly air in the system.
    Save ur engines!
    It's all about JDM.
    CA to GA
    Before you are jumping to any conclusions, make sure you inspect around your engine (like coolant hoses , the coolant thermostat housing, the mating area of the head and block where headgasket sandwiched) to see if any coolant leaking from or around those areas.. Next check each cylinder by taking out each sparkplug out and shining a light down to inspect if any moisture or coolant inside or on top of piston. Get access of a radiator pressure tester and test if pressure is holding and no air leaking, look on your haynes manual. Could be a thermostat or hose...hopefully not your headgasket.
    I won't advertise because I'm not paying to
    Mar 2010
    well i drove the car today again. and it ran fine. but i will jack up the car and look under and on top to see if anything is loose. thanks for all the info.
    Mar 2010
    yea i know ppl kill me on here. acting like they are perfect and that they have never raced back in there days. but whatever. but what do u mean hg, wp.
    barrow county
    like they said check all plugs
    my suggestion is that you probably revved the shit out of it and probably cracked the radiator
    Mar 2010
    head gasket and water pump. If the system has air in it, the air got in somehow..
    Quote Originally Posted by Sir_Christopher View Post
    everyone knows vtec is a mate'n call
    Fayco
    u might just have a loose hose somewhere. check for leaks.
    Save ur engines!
    ಠ_ಠ XanRules's Avatar
    Dining in Hell
    This.
    Nope, sure haven't. Have I played around on open roads? Yes, quite a while ago, and it was dangerous and illegal. And I was never stupid enough to talk about it on the internet.
    Back in where days?
    Someone mentioned hg earlier. This is probably a headgasket. Similarly, a wp is probably the water pump, mentioned earlier.
    Correct Fitment Crew CEO
    Because Only Turds Should be Dumped and Flushed.
    2012 Hyundai Veloster / 1960 Fiat 600D
    Mar 2010
    back when u was like 18, 19.its hard to believe that ppl on here say they havent never raced in their life. i dont believe it. people are like i hope u wreck your car or blow your motor. if there were no cars around or people around i dont see the harm. but whatever ppl can say what they want. thanks though for helping me out.
    Swap king james497's Avatar
    Jul 2009
    N. Philly
    pressure test and your question will be answered
    b20b is in!!!!
    b20b vtec coming real soon!!!
