Results 1 to 10 of 10
Thread: 93 Civic hatch running rich
    Certified Gearhead Umby's Avatar
    L'ville / Gwinnett
    Default 93 Civic hatch running rich
    I've got a 93 Civic CX.
    I recently dropped in a JDM ZC motor (D16A6).
    The car runs great and my fuel economy still seems normal but over the last 3 or 4 days I've noticed a small puff of black smoke at high rpms or under strain and my tailpipe is collecting a pretty fair amount of soot.
    In the last 5000 miles its had fresh NGK plugs and NGK wires, new cap and rotor, and a new fuel filter.
    I haven't pulled the plugs to check them yet but as of 2 weeks ago they looked like they were burning perfectly.
    The car is running on the factory P05 ECU and has the one-wire o2 sensor.
    I'm not getting a CEL and the ECU isn't storing any codes.
    I haven't taken it for emissions yet this year so I'm not sure what my levels are.
    What are some things that could be causing this?
    barrow county
    oil ring
    L'ville / Gwinnett
    If you mean psiton ring that's not it. Compression is good and it doesn't comsume a drop of oil. Oil smoke is blueish in color and leaves more of a greasy film(as a Mitsubishi owner you should be well familiar). Something is causing the car to load up on fuel under strain but I don't know enough about how Hondas process information to start troubleshooting.
    barrow county
    theres 3 rings, oil ring and 2 compression ring. if the oil ring is bad, oil is getting into the combustion chamber and burning leaving black smoke ( more noticeable at high rpm)
    blueish i think is running rich? or lean?
    Mitsubishi burns oil yes, but most are not noticeable like in the eclipse i use to own
    L'ville / Gwinnett
    Blue smoke is oil. Black smoke is carbon being created by an excess of unburned fuel. My car is running rich at high rpm... Not burning oil.
    what ecu
    barrow county
    nvm
    L'ville / Gwinnett
    P05
    L'ville / Gwinnett
    Quote Originally Posted by blue_gt View Post
    nvm
    Whatever man
    barrow county
    no you were right
    rich = black
    oil = blue
    but you said your running rich
